can a 86 short block go with 88 heads ?
That would be a cool combination 11.5:1 compression! I think there are a few things you need to do with the block, like make a little spacer for the timing on the flywheel sensor, and a couple of other small mods
mk
mk
As Mark mentions, the compression ratio will be quite a bit higher. This should be taken into account with how you plan to use the engine. Could be good, could be bad... you need to consider what fuel you'll use as well as the cams / cam timing.
Also, if you plan to run the S4 intake manifold, you need to trim two button points in at the top of the valley, mid way. The protrusion will interfere with the S4 style manifold...nothing that a die grinder cannot take down without harm to the block.
Enjoy.
Enjoy.
Thanks for the replies.
Im not trying to make a high performance engine, one of my friends sayed that he knows of two 86 short blocks that I may be able to use, had no Idea the compression ratio would change that much. It looks like no one has done such a swap on their car.
The RoW 32V engines are reasonably rare - Australia and Japan both got 'em. A lot of European markets had the 16V S2 engine in '86 with the S4 suspension, brakes etc.
ROW '86 32V pistons will create around 10.8:1 CR without any piston top modification.
If you care about performance, i would use the 85 pistons, if they are a set matched to the block and crank/rods, it will save you the balancing act. (more cost for less power if you use the 88pistons)
as far as the valve cuts, the cuts are very very faint. (less than 2cc) a dremel of the outer circumference will work just fine to give the emergency clearance . engine will run fine with the cuts the way they are, without ANY issues. if you dig them a little deeper, you might even be able to make a non-interference engine!
Former Vendor
