928 Forum 1978-1995
Sponsored by: 928 Specialists
'84-'86 EuroS dyno charts
Old 02-21-2009, 02:53 PM
  #31
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,134 Likes on 1,208 Posts
Originally Posted by BRETT AINLEY
I will think about a tranny cooler, but I am not sure it will cool fast enough for my short runs.
Depends on how you install it. This is similar to how mine is setup on the 79:
http://members.rennlist.com/pageauto/transmission.htm
Individual injectors spraying directly on the gears. But I'm sure you already thought of this......
Old 02-21-2009, 04:28 PM
  #32
Brett928S2
Brett928S2's Avatar
Originally Posted by soupcan928
You're kidding right?
Hi
Nope, I was serious. most of my runs with Nitrous running are a maximum of 2 miles or around 90 seconds max....you think a tranny cooler will make much difference in 90 seconds ??
All the best Brett
Old 02-21-2009, 04:32 PM
  #33
Brett928S2
Brett928S2's Avatar
Hi
Is that a 3 speed or a manual ?
It looks nothing like my 4 speed auto....
Also, if you read the post above this, would you think yours would make a serious difference to cooling the fluid in 90 seconds ?
All the best Brett
Old 02-21-2009, 04:37 PM
  #34
hacker-pschorr
S4 5-speed
I forgot your car is an auto?
Going from no cooler (or the factory one) to a larger unit with multiple injectors spraying cooled fluid directly on the gears?
Short answer: yes
Old 02-21-2009, 05:09 PM
  #35
Brett928S2
Brett928S2's Avatar
S4 5-speed
Short answer: yes
Hi
Yes , 4 speed auto , and as I would need to pull the box for a tranny cooler (as not much room around it with twin pipe exhausts) I doubt it would be worth my while....the LSD change doesn't need box removal....
All the best Brett
Quick Reply: '84-'86 EuroS dyno charts
