Won't go into 2nd, but all other gears perfect
Can also be a worn hub that allows more movement than was designed so the syncro can get stuck , run up on the ramp too far. Some 911 drivers early trans did this often when rushing a shift , the old Porsche design syncro just does not like quick shifts very much. Not nearly as forgiving as the Borg-Warner style... Not saying you did anything WRONG at all the trans may easily have had worn parts just waiting to act up.
Great there is hope for recovery ! don't need no stinking second gear !!!
The socket lining in mine disintegrated over a span of about 500 miles, mostly city driving with lots of shifting. Once it starts to go, it'll go pretty quick.
lift the boot see if the forward rod is moving back and forth if so the the front socket is worn....lift the body off the suspension and driveline to replace
In finding out more about the trans, I found its a later unit:
https://rennlist.com/forums/928-forum/456500-edit-2400-rpm-at-80mph.html
But I will have to remove it because it does not seem external.
I had the same problem after replacing the Syncros in my 1978. I was shifting into 2nd for about the fifth time on my first test drive when it quit working. I could tell the Shift Ring wouldn't slide over the Syncro, and no amount of forcing of the Shift Lever would help. I assumed that the Syncro formed a burr, or was binding so I disconnected the rear Shift Linkage, and tapped the Shift Rod directly with a Mallet, and with verry little effort it dropped right in to second Gear. I haven't had any trouble with it since (500+ miles). I was surprised at how little force is really generated by the Shift Linkage, as three little taps of the Mallet pushed it past the sticky spot, and I was shoving the Shifter REAL hard previously. might be worth a try. Good luck!
So I took for a test drive and pushed as hard as I could, risking breaking something else. I knew I was swaping boxes so didn't care if I broke something - i'd fix it.
Well, it went in perfectly with alot of force, and now goes in like all the other gears - very nicely. I tested it up to an redline shift several times, and its perfectly fine.
Thanks!
Dan
'91 928GT S/C 475hp/460lb.ft
