(edit)2400 rpm at 80mph
That's not a 2.75 rear end, is it.
Anyone have a gear chart for a 2.2?
Seriously - I'll pull this one, put the 78 trans and TT I rebuilt in there, and rebuild this set and put it in the 78. (or "fix" whatever I did when I lost 2nd on the "test drive"
I could do that swap in a day with some help and be on the road the next.
I think, unless something else is off, that Devek put a 2.2 trans in this thing when they rebuilt it.
Might have swapped in a later box rather than spend the money having the early one rebuilt.... take a look at the numbers on the trans.
It doesn't show that in the receipts, but you never know. If this is true this is a great thing. I was wondering why the car wasn't as peppy as the 80 I drove at your store.
I was about to say, if you are turning exactly 2,000RPM at 80mph, then at 6,000RPM you would be going 240mph!! Are you sure you read that right?
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
I will do 80 on the way home and double check.
Well, no 160, but verified that at 80, I have right at 2200rpm. So now its time to get under there and see what the 28/0x is. Methinks its like an 83 or 84 usa 2.2, but not the borg warner 2.2
Dan
'91 928GT S/C
maybe you have the 89 2.64 rear?
Well, I will get under there in the morning and see for sure.
