NEW COST EFFECTIVE PRODUCT - Fuel Rail Pressure Gauge
#91
The seal of a tapped original nut is better, but doesnt emulate the original due to the "ball" not doing the sealing. those german nuts are pretty tough.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
the threaded adapters might not have the same tollerances and dont seal well enough, even with the "o"ring. Im sure a little teflon tape could fix that, and i might use some just for my tests as I just dont like a drip , drip drip of gas coming out.
I have a shreader valve that was supposed to be used in SCCA racing, and has the same threads as the fuel gauge. but, i aint going to use it until i get a threaded nut that is tapped from the stock nut. (SCCA agrees and lets me off, especially since fuel checking is not reall done with our class, though it could be as we need to use unleaded street gas)
mk
mk
Hi Mark,
The ball is inside the special machined adapter. It is machined into the adapter. Monobloc.
Never seen a leak on the older style where we drilled and tapped the original nut.
This emulates the original seal 100%. If the original nut did not leak neither will this.
Up to the personal user if they want to leave it on there permantly or not.
Roger
Roger
#92
Seems pretty poka yoked to me. Nice job Roger. FWIW, I have 7 + experience with the ole liquid teflon method on 3 cars with no leaks, but I think I should upgrade my setups to Roger's new one, as extra safety measure. I must admit that tape always leaked, but not the liquid. Also FWIW, the only time the gauge is useful is when troubleshooting no start issues or assessing injector leakage, all of which are important to save time.
#93
Basic Sponsor
Mark,
I think you missed the point. The adapter has the ball in it and does not use an O ring.
Exactly the same as the original nut and ball. How would a nut on its own be better?
Glad I took the time to post the photograph of the adapter 8>)
That is the whole reason why we spent all this time and effort to copy 100% the original design.
Roger
Roger
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#94
Great stuff Roger, as always, as well as a great price.
#95
#96
Basic Sponsor
Hi Randy,
You are on the list and thanks.
They all have the air bubble as its oil filled to dampen the needle.
Roger
Roger
#97
But the bubble would technically be a bit smaller or less noticeable, since the picture shows the piece at an angle. When viewed straight on, these bubbles are not as large.
#98
#101
Basic Sponsor
Everyone who responded to this thread wanting a FPG is still on the list.
Jim you are way high on the list.
Roger
Roger
