928 Forum 1978-1995
Sponsored by: 928 Specialists
New remote turbo thread
Old May 3, 2008 | 11:03 PM
  #211
Mongo's Avatar
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
RJT I have photoshop. If you want, I can resize it.
Old May 4, 2008 | 12:05 AM
  #212
Dennis Wilson's Avatar
Dennis Wilson
JT,
Your gain is great for the amount of boost you are running. Ideally, one bar (14.5 psi) should double your HP. Upping your boost to 7.25 psi (.5 bar) should give you 405 hp as long as the heat is managed and you don't run out of fuel. Have you decided what level of boost you are going to run?
Dennis
Old May 4, 2008 | 12:27 AM
  #213
Tom. M's Avatar
Tom. M
Deleted
The recent result is their base kit...stock S4 with AT....running a 5 pound spring...so..stage 1 if you will 380 hp...(dyno pac..not dyno jet..add 10 % to get approximate dynojet #s)...I believe stage II is going to be 8 to 10 psi..and stage III will be 14 or 15..but not sure if he wants that on a stock motor... Good numbers JT....and Chuck...
Old May 4, 2008 | 01:10 PM
  #214
atb's Avatar
atb
Old May 4, 2008 | 01:35 PM
  #215
Tom. M's Avatar
Tom. M
Deleted
Hmm...looking at that..the flappy is not coming into play...does the boost negate the flappy effect? Interesting..and nice numbers though..
Old May 4, 2008 | 02:33 PM
  #216
Mongo's Avatar
Mongo
Fuse 24 Assassin
I just noticed that too. Is the flappy even functioning????
Old May 5, 2008 | 02:10 AM
  #217
dprantl's Avatar
dprantl
Pressurizing the intake makes the flappy useless since there are no more resonance waves, just pressure. In fact, on turbo cars the shorter the intake runners the better. Notice that NA 993's have VarioRam but the 993TT does not.
Dan
'91 928GT S/C
Old May 5, 2008 | 12:30 PM
  #218
Mongo's Avatar
Mongo
Fuse 24 Assassin
Dan
'91 928GT S/C
Ah, now that makes sense. The pressure complete negates the purpose of having that extra butterfly.
Old May 5, 2008 | 01:16 PM
  #219
89 928 turbo's Avatar
89 928 turbo
Andy Serrato
Actually, using the ST we adjusted the flappy opening RPM down so that it is opening at about 2,750 rpm's for WOT and when the car is in cruise, at about 75mph we are 100% spooled up and just on the edge of going slightly positive on vacuum/boost and around 2,800 rpm's
The car itself liked to run a little richer (some varience on the ST AFR vs the Dynopac AFR due to location), but in the mid-four thousand range it tops out a bit, but the AFR is dropped into the low 11's - high 10's (on the ST)....some HP gains there, but still good performance with a safety factor for detonation. We are moving over to the EZK side to look at # engine knocks and adjust timing this week.
jt
Old May 5, 2008 | 01:49 PM
  #220
Mongo's Avatar
Mongo
Fuse 24 Assassin
I can't really read the AFR graph too well, but are you saying it's running lean in upper RPMs?
Old May 5, 2008 | 02:07 PM
  #221
89 928 turbo
Nope, it's actually going a bit rich.....12.25 or so is the target, we went into the 11's.....a little more tuning of the fuel to bring the AFR up a bit, would gain a little more HP's.
Old May 5, 2008 | 08:30 PM
  #222
Mongo's Avatar
Mongo
Fuse 24 Assassin
Well I can't say running rich is bad. I've had my share of experiences running a motor lean.
Old Aug 26, 2008 | 02:50 PM
  #223
Courtshark's Avatar
Courtshark
bump... status check.
Old Aug 26, 2008 | 02:54 PM
  #224
atb's Avatar
atb
They just completed a dyno run with their 7lb set up, I'm supposed to be getting the charts to post any time now. I think Chuck said he was in the 420hp range.
Old Aug 26, 2008 | 02:57 PM
  #225
Courtshark's Avatar
Courtshark
Sweet! Once I get my Shark back from the shop it's turbo time. 7 lbs sounds perfect; not too aggressive, but still very effective.
Question... is it LSD equipped? My shark is not. But that can be fixed.
