928 Forum 1978-1995
Sponsored by: 928 Specialists
Changing Motor Mounts Tomorrow
Old 02-03-2008, 02:23 PM
  #76
marton
marton's Avatar
Great write ups & fotos
HTML Code:
the INFAMOUS crossmember support didn't give much of a fight so
got those bolts in without too much effort
When I did mine i had read so much about this problem that I tapered a couple of old bolts with a grinder & banged them in on the "wrong" side with a hammer, then I could just push the correct bolts in on the right side.
Marton
Old 02-03-2008, 11:41 PM
  #77
Dwayne
Dwayne's Avatar
Originally Posted by H2
Dwayne,
I know it helped a lot to pull your engine, but what materials/solutions did you use to get it so sparkling clean? Any 928 owner would love to have an engine and undercarriage area looking that pristine.
Harvey
Hello Harvey,
Yes, having the engine out was a great help to get things cleaned up. When I had the engine out, I let the machine shop clean the block and heads. I disassembled the block, kept the crank at home and sent the 'chunk aluminum' to the shop for a cleaning. For the rest, I cleaned at home. Most of the nuts, bolts and washers and plastic parts and painted metal parts, I used Orange Blast - a citrus cleaner I got at Wal-Mart. For caked on grease and grime on metal parts (not painted), I used carb cleaner. Used a wire brush on a lot of metal, non-painted parts and nylon brushes on soft parts. I also purchased some sheet plastic and a small kiddie pool to do the cleaning to keep the overspray off the concrete. Cleaning did take a significant amount of time.
Thanks for the post and for the question!
BTW, I'm a fan of the NW, I visit there at least 3 times a year!
Old 02-03-2008, 11:43 PM
  #78
Dwayne
Dwayne's Avatar
HTML Code:
Marton
Hello Marton,
Nice tip, clever!...I'll remember it next time I have to do this....THANKS!
Quick Reply: Changing Motor Mounts Tomorrow
