Fuel rail sponge
Aug 27, 2007 | 02:04 PM
Fuel rail sponge
Does the sponge serve any purpose, or can I lose it?
Reason: added pic
Aug 27, 2007 | 02:27 PM
Bert..........its used as insulation.
Here's a solution John P used:
Aug 27, 2007 | 02:33 PM
Quote:
Originally Posted by
bfellows
PS ... you've already lost it
, by the looks of the pic.
The 1/2" pipe insulation Malcolm shows will do very well! - two 3' lengths for $1 here.
Aug 27, 2007 | 03:57 PM
Under the LiftLifetime Rennlist Member
This stuff was eliminated somewhere in the 90s. If you buy replacement rail covers now, you get ones with heavy foam molded in, although it does not insulate the underside. I've done the pipe insulation mod.
Aug 27, 2007 | 04:18 PM
Sorted! Thanks all for the usual quick responses!
Aug 27, 2007 | 04:24 PM
The replacement covers are not that expensive.
Aug 27, 2007 | 04:31 PM
Range MasterPepsie Lite Lifetime Rennlist Member
Us Murph SC guys run 'em nekkid...........
Aug 27, 2007 | 04:34 PM
Captain Obvious Super User
The early 32Vs were naked from the factory!
Aug 27, 2007 | 04:36 PM
Electron WranglerLifetime Rennlist Member
Bill - did you install in situ or with the rails off?
Alan
Aug 27, 2007 | 04:37 PM
Craic HeadLifetime Rennlist Member
Imo000
Phew! I thought someone had stripped mine afterward. Thanks.
Aug 28, 2007 | 10:24 PM
the flyin' scotsman wrote: Bert..........its used as insulation. Here's a solution John P used:
http://forums.rennlist.com/upload/svc_intake_9.jpg
Nifty. I was wandering arounbd in Home Despot today and noticed they carried a foam panel insulation adhesive. That might save some detail work with zip ties.
Aug 29, 2007 | 01:10 AM
Alan: You should be able to do it in situ.
Aug 30, 2007 | 09:41 AM
Does anyone know what effect this insulation has on fuel temp? With/without? Fuel is constantly recirculated back to the fuel tank, right?
Also, isn't there a fuel line cooler/heater thingy at the firewall? What does that device do?
Would it be helpful to insulated the fuel rails on an '85?
Aug 30, 2007 | 09:56 AM
Rennlist Member Rennlist Site Sponsor
I suspect that the purpose was noise insulation, rather than heat insulation.
Aug 30, 2007 | 10:22 AM
underdog928
I would leave it as is. One less thing to get soaked in gas and catch on fire.
