Scat Stroker Crank Balancing Act (6 cwt)
#106
Former Sponsor
Joseph's 8 counterweight Scat crank had to have the counterweights machined down for the 5.850" rods and pistons to clear the crank (it appeared that the crank was made for 6.000" rods.) We used J&E pistons and Oliver rods for this engine. It took a whole bunch of Mallory to balance this combination....so it would make sense that the 6 counterweight version might require more Mallory to get it to balance. Interestingly enough, with the Carrillo rods and 968 pistons, the last Moldex crank we had spun needed no Mallory at all. Kind of strange....seems like the two cranks should have similar needs in terms of weight. Anybody got any thoughts on this?
gb
gb
#107
In order for two same design cranks to function differently only explanation is one has to be made from heavier material. In case counterweight design is different it could easily explain several 100 gram differences on what weight pistons work without added mallory. Easiest variable is how thick those weights are.
8CW heavy Moldex
![](http://members.rennlist.com/vilhuer/IMG_2375.jpg)
Greg's 6CW Honda Moldex
![](http://forums.rennlist.com/upload/moldex_honda.jpg)
6CW Scat in Stan's picture also has thick looking first and last weights but four weights in between could be thinner than in Moldex versions. Maybe solution to Stan's problem is not just drilling crank hollow to allow as much space as possible for mallory. Instead problem could be solved by making counterweights thicker by adding more material on their sides. It looks like 968 pistons would allow some thickness added in Moldex crank counterweights on rod side of the weight.
![](http://members.rennlist.com/vilhuer/P1010778.jpg)
#108
Most counterweight thickness is dictated by journal spacing and proximity to the main webs and rods on each side. Erkka's pic above only shows one rod, but if you looked at the other one, you'd see there isn't much space there. So, you can't add much to the sides. I notice that Greg's crank has a large hole drilled in the rod journals- can't tell if the Scat is that way or not? That is common practice on most racing cranks, and makes a big difference in balancing.
About the only place you see a difference in counterweight size is out on each end of the counterweight, where it is cut for 'knife edging".
So, Greg BBRD, if Joes crank had been made for the shorter rod length originally, the counterweight would have extended out farther on the sides, and its maximum OD may have been larger, to make up for the loss in material in the middle to clear the piston.
#109
#112
DEVEK 3rd gen cranks are gun drilled down the center, have journal lightening and bull nosed...not knife. Too much debate...
Thanks in advance
Greg
#113
Alot of weight is taken off the center.... quite a few pounds.....Translation, I don't remember...I can calc it though. Takes a std cam plug for the rear seal.
But the main purpose was for crankcase ventilation....the best blocks for reduced resistance to crankcase air movement is the GTS block, but it is also the weakest for high hp applications.
I have always wanted to follow the NASCAR folks and build a really high output two valve, but it really is easier to get high hp form the 4 valve. A bit lazy I guess![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Cheers,
marc
Cheers,
marc
#114
Originally Posted by marc@DEVEK
I have a set of LS7 Ti rods avail...new in box
#116
Steve, we will talk about dry sump once we have aproven concept...yea, we are go9ing to get rich making dry sump pans, right ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
You azre right...off topic.
Stan, will think about it....we might be close to a deal....
Marc
Marc
#117
Originally Posted by Stan.Shaw@Excell.Net
I would be interested if you will take a used set of 968 pistons in trade, say for $1k?
http://cgi.ebay.com/ebaymotors/ws/eB...m=260131808818
#118
Originally Posted by SwayBar
Just for reference, here's what a set of LS7 titanium rods went for on eBay:
#120
