Rear wheel hop under acceleration
On my '88 ( no limited slip) I never had wheel hop with old worn out shocks or new Bilsteins.
I have bad wheel hop on the '91 GT. I even adjusted the Koni shocks to full hard with no effect.
Do any of the cars with no limited slip have wheel hop?
Range Master
Pepsie Lite
Pepsie Lite
The addition of another 200 hp seems to have cured any wheel hop I had.....tires just spin like they were made out of butter.....................I am very careful on wet roads......break the tires loose....hit the revlimiter PDQ...........
:0
:0
Gretch,
Did you have wheel hop before the SC? If so, yet another reason to get a SC. I have some wheel hop now, but it is better since I put onthe bilstein/eibach coilovers.
BTW, started the Murf SC install Sunday night. Wheel hop be gone!!!!!!!!
928 Collector
Since going to 17's on the 5spd S4 I get wheel hop on breaking them loose. I also have much less grip. Pressure is 32 or 33 all-round.
With 16 Design 90's I had zero hop and was much happier with the roadholding in general.
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by Jim R.
Gretch,
I've always felt that the 928 is less tricky in the wet or low traction times then other cars, say, Z-28s, Mustangs, Chevy Vans The momentum seems to not happen so....quickly to the side.
I get wheel hop on wet, none on dry - just lots of smoke. It seems to redline very fast once you start spinning and the smoke plume is huge.
Used to have 245's on back, now 275's - not much difference to above.
I do get some wheel hop with the 17's, mostly on wet pavement. My shocks are probably shot and I should probably lower the air pressure in the back. Winter project - Eibach/Bilsteins (along with a few others).
