Found all the missing pieces in an oil passage....*pics*
928 Engine Re-Re-Rebuild Specialist
After a nice weekend in Vegas, I spent a little time in the garage tonight. I took off the head and found all this good stuff crammed into the oil return passage...
Originally Posted by V2Rocket_aka944
****...what the hell happened? Broken chain?
Originally Posted by the flyin' scotsman
what caused the head to fracture? Did the tensioner sieze?
But you're screwed for one head.
Guess its time for some stage-3 racing heads...
Dave.........you did work on his engine recently; did you re-mount the tensioner? If everything else is good then the problem happened at the tensioner or a head fracrure........unreal!
Exactly what happened to mine when the tensioner pad broke, evidently the same thing happens to 944 and 968's i.e. the mounting point for the tensioner breaks. I feel for you and good job for not getting too discouraged.
I found small fragments all the way to the oil pump but none further on (I split the block just incase), unlike our 4 banger bretheren the 928 continues to run on 4 cylinders which only helps ingest the debris.
Chris
Chris
Chris
Chris
Under the Lift
Man, Big Dave, that's a load of junk. I'm almost surprised you didn't find some old coins, a few pertrified french fries and a wedding ring down there.
