928 Forum 1978-1995
Sponsored by: 928 Specialists
Koni vs. Bilstein vs. Boge question
Old 12-19-2006, 04:01 PM
  #61
SharkSkin
SharkSkin's Avatar
Originally Posted by BrendanC
Cool. I was just thinking of the Two fingers, pointing at your eyes, then pointing out.
ANother somewhat relevant one from my site: And the one attached I found with a bit of help from
/hijack (sorry)
Old 12-24-2006, 02:53 AM
  #62
Bill Ball
Under the Lift
Bill Ball's Avatar
Originally Posted by fabric
That is true, good tip Bill! I"ve added that info to the page.
Coming back to drop in a couple of pics of how I check ride height. I'm lucky enough to have a 180mm/7 inch ruler - just the right length. A longer ruler gets in the way, at least upfront. Just cut to fit.
The rear is easy. This is 163mm.
The front checkpoint is in the middle of the lower A-arms rear bracket, very inaccessible unless the car is on a lift, as shown here.
As I mentioned before, this checkpoint is about 10mm above the bracket's outer lip low point. You can get to the outer lip of the rear bracket from behind the front tire. It's a bit awkward but even my short arms can rearch it. Here it is, reading 139 (there is a little paralax error from the camera angle). Add 10mm to get 149.
Yes, I'm probably going to raise the front 10mm.
Old 12-24-2006, 08:53 PM
  #63
BC
BC's Avatar
/hijack (sorry)
Awesome. Thats exactly what I was looking for.
Quick Reply: Koni vs. Bilstein vs. Boge question
