928 Forum 1978-1995
Sponsored by: 928 Specialists
Show us under your hood!
Old 07-17-2009 | 01:59 PM
  #151
blown 87's Avatar
blown 87
Rest in Peace
Old 07-17-2009 | 02:44 PM
  #152
RichS 1986928's Avatar
RichS 1986928
It's not too impressive but knowing the time and $$ it took me to get her here,
I'm proud.
Old 07-17-2009 | 03:03 PM
  #153
928SS's Avatar
928SS
Road Warrior
Originally Posted by Abby
Hi Ali!
Thanks for the kind words.
The engine is an 85-86 block, as well as heads/cams that have mild porting and a S4 intake. I'm using 951 forged pistons with custom forged rods from Pauter and a 5.0 crank with the cross drilling mod. In addition I have a mid mounted T-67 DBB water cooled Precision turbo that has custom plumbing done by John Kuhn. And I am also running custom inter-coolers designed by John. Fueling is done through the stock management system that has been Shark Tuned by John, along with some goodies from John Speake (SuperMaf and dual MAP sensor) using 36lb Marren Racing fuel injectors and a Bosch 044 fuel pump with a modified in tank pickup. There is also a BEG rising rate fuel pressure regulator to tip in some additional fuel pressure on the top end. The current tune was done at 8psi resulting in 434RWHP/488RWTQ. I have an electronic boost control and this fall we will turn up the screw to 12psi and re-tune the car. It's been A LOT of work however I am starting to see light...shhhhhh not going to 'curse' myself by thinking I'm almost there
Thanks for asking about it!
holy manly blowers! that's a seriously nice effort! but that's the street car, right? for the track wouldn't that put you into the insano top class against fabricated race cars from the ground up?
that's what happened w/my stroker in the PCA stuff
Old 07-17-2009 | 04:57 PM
  #154
DonT's Avatar
DonT
Klaus - photo taken by Pat @ Hershey 2008...
Old 07-17-2009 | 08:21 PM
  #155
Vlocity's Avatar
Vlocity
Here's an early version of mine.
Old 07-17-2009 | 09:35 PM
  #156
zoltan944's Avatar
zoltan944
Rich thanks for the pic! I am looking into a paint refresh and thinking about a silver, your color helps me out!
Need something to pop with the red!
Old 07-17-2009 | 09:42 PM
  #157
Randy V's Avatar
Randy V
Originally Posted by Mike Frye
Randy showin' off the engine jewelry! That was nice! What about the GTS, how does it look in there?
Sadly, the GTS looks quite plain and neglected under the hood.
Old 07-17-2009 | 10:19 PM
  #158
JWise's Avatar
JWise
After a recent intake and cam cover refresh:
Old 07-17-2009 | 11:37 PM
  #159
Mike Frye's Avatar
Mike Frye
Craic Head
Some awesome stuff in this thread!!!
Time to get crackin!
Old 07-17-2009 | 11:48 PM
  #160
davek9's Avatar
davek9
Here is one I shot of my '85 when doing my MM's this spring.
Old 07-20-2009 | 12:10 AM
  #161
scottzj's Avatar
scottzj
Here is my junker. Its needing alot of work but it will eventually get there. Heck I only have had it for a few months.
Old 07-20-2009 | 03:49 PM
  #162
Richter12x2's Avatar
Richter12x2
Here's one of my intake after the R&R - the rest of the engine bay is still a work in progress. It was nighttime when I finished putting everything back together, so I'll try to get a daytime shot soon.
With that said: If you don't have the patience to disassemble, clean, and prep before you paint, don't try this at home! Those of us who buy your cars after you give up on them don't want to spend 2 months sanding poorly prepped rattlecan blasts off the expensive magnesium intakes. :P Although it is nice to pick up a 5.0 928S for under 3k because the engine bay looks atrocious.
Oh, and the red liner on the radiator hose is left over from the Previous owner. I started to cut it off, but the hose underneath is coated in crusty globbed silver paint, so it actually looks better on for now.
Old 07-20-2009 | 06:22 PM
  #163
RichS 1986928
What kind of Bone-head would put spray paint directly on that engine? I'd be afraid to look
at the rest of the car...
Old 07-20-2009 | 06:43 PM
  #164
Richter12x2
Remarkably, the exterior and interior were in good shape for a 24 year old car, except where someone tried to use touchup paint to cover some scratches (for a custom paint color car. )
The engine was so bad it was hard to tell where one part quit and the next one started because 4 different colors of spraypaint had been used without masking, or prepping anything, much less removing parts!
Old 07-20-2009 | 07:15 PM
  #165
Hold On's Avatar
Hold On
These pics are great. I have to ask .....do you guys actually drive these cars. ??? lol I like to keep my stuff nice but some of these are just over the top.
