My sad suspension
#258
Originally Posted by Bill Ball
My only thought is that something must be amiss lately with Konis quality control. The first set was weak initially and got much weaker over time. The replacement set they sent me was better, but still under damped for our springs. You can do what I did - install them and see what you think. The difference between all these setups was downright obvious on my car. The Konis were soft based on bumper push and soft based on driving. Cadillac ride. With the rebound damping cranked up they were sloppy on compression and harsh. The Boge Reds were about as soft on the bumper push as the Konis, but better damped on the road. The Bilsteins/Eibachs were strangely annoying (jiggly, nervous) with poor bump control, perhaps due to some mistake in assembly (the springs are shorter and the rears did not require a spring compressor - weird). The Bilsteins with my stock springs (I do not have sport springs after all) seems to be just about perfect - WAY firm on the bumper push, but civilized and controlled on the road. I think for everything but the track, where you might want everything dialed up even firmer, the Bilsteins or Boge Reds will work well. Good for daily driving, good for twisties and good for high speed stability and control for open road racing - that's what I need. I have no experience with Hypercoils, but I know they have a good reputation, as do the Eibachs. At this point I can't explain my adverse experience with the Eibachs, although a few others have had similar experience. Making sure the ride height is up, which preloads the springs, seemed to be important. My handling improved, and, of course, I had fewer front spoiler hits in turns, as I got the ride height close to stock. But even at 160 front and rear (still below stock, but higher than most people run), these springs had strange street manners. No such anomalies with the same Bilsteins paired with stock springs.
The place that redoes Konis is up in Canoga Park. Should be pretty easy to get done right.
#260
Under the Lift
What is the cost of redoing the Konis? Koni will repalce them for free if you are the original owner and have a receipt. However, having them revalved more to your liking is a better idea after my experience that the factory replacements were too soft too. Considering the cost...Bilsteins are about $200 a corner. Boge Reds about the same.
#261
Supercharged
I bought all the bushings, and have them ready to install with my new 20-ton press. However, the old ones look fine. There really isn't any clear indication they are bad, but when my car was wallowing around after a second set of shocks, I bought them thinking that had to be it. I want to change out the steering rack first. If that and an alignment fixes the sensation of wandering and tramlining, then I'll just save the bushings for later, as I don't think they are contributing anymore. The wandering and tramlining seems better after the final shock change. I might have changed the front alignment for the better with the lower A-arm removal and reinstallation required when changing the front shocks this last time.
#262
Under the Lift
Originally Posted by Andrew Olson
Thanks Bill. I guess that's good news for the rest of us. At the beginning of this thread I was expecting something like worn bushings or similar that was going to force us to look for some type of solution there. My wallet is relieved that this is not the case.
#264
The digressive valving of the Bilstein gives you firm resistance to slow movements like when you bounce the car BUT softer resistance to quick movements which is just part of what makes it a far superior design than that of other older technology shocks. I am just very happy to hear that you got it sorted out to your satisfaction.
#265
You are saying that the oil-based Konis are not superior to the bilsteins?
#266
Bill
Great to hear you got it worked out.......I figure I'll have to replace mine one day in the future.....just a touch too much wallowing during mid corner bumps now.....but the ride sure is nice! I gave my friend with the 87 5 speed (bilsteins all around) a ride in mine and he commented on how smooth the ride was!
#267
Under the Lift
Thanks for explaining the discrepancy in the bumper test across brands. I expected the Bilsteins might be a bit harsh on the road. Not so at all. I get happier with the Bilsteins each time I take a ride.
#268
Under the Lift
#269
I know Garth has a set of oil-based Konis he loves, but aren't these an older NLA design, different from the current low-pressure gas Koni 8240? If you have the older oil-based Konis, then none of my Koni experience comments would be relevant.
