928 Forum 1978-1995
Sponsored by: 928 Specialists
Has anyone seen an oil pump do this? Seized pump - internally broke apart.
Old 07-12-2006, 11:49 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,204 Likes on 1,243 Posts
Default Has anyone seen an oil pump do this? Seized pump - internally broke apart.
This was a suprise - car stared very hard, died. Started it again, died. Started it a third time, gave it some gas - heard a howling noise, oil pressure at zero - smoke coming from the motor.
Luckily the amount if time I ran my car like this was very minimal. Smoke was the timing belt being stripped of its teeth.
Pics speak 1,000 words:
hacker-pschorr is offline
Old 07-13-2006, 12:02 AM
sublimate
Gluteus Maximus
sublimate's Avatar
My guess is a foreign object got in there. Never seen one fail like that on its own.
sublimate is offline
Old 07-13-2006, 12:14 AM
aircooler
aircooler's Avatar
Hacker, that's ****ty man
aircooler is offline
Old 07-13-2006, 12:20 AM
Big Dave
928 Engine Re-Re-Rebuild Specialist
Big Dave's Avatar
Certainly seems like something is stuck on one of the teeth, but I don't see material missing from the gear. Have you pulled it out to examine the particle?
Big Dave is offline
Old 07-13-2006, 12:22 AM
hacker-pschorr
The part stuck in the teeth is from the little thin piece that runs along the gear on the upper right side (in the last picture)
Old 07-13-2006, 12:24 AM
WICruiser
WICruiser's Avatar
I don't want to make this worse than it is, but how long is "minimal"? Zero oil pressure is never a good thing.
The next question is what else made it through the pump into the oiling system before the pump seized?
Good luck, let us know what you find.
WICruiser is offline
Old 07-13-2006, 12:32 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Argh! Hacker, you seem to be taking this very philosophically. I would be throwing things.
Bill Ball is offline
Old 07-13-2006, 12:33 AM
hacker-pschorr
These questons have been going around my head for a while. How long is minimal here? 2-3 seconds each try - I tried 3 times. It didn't take long for my brian to realize something was wrong and turn the key.
I have a huge gamble here. Put in a new pump and pray that anything that "made it through" was caught in the filter.
-or-
Yank the motor and rebuild.
I have a 5.0 S4 engine waiting for a rebuild to go in. I'm thinking about putting in a pump (used ones are a plenty from the many torn down motors between "the group") and drive it. If it gets worse and tears apart the block - speeds up the 5.0 upgrade project. I know to some this is a very stupid way of looking at it - either way this motor is eventually coming out to never be used again (I have some local 4.7 engines I can buy cheap). So if I bolt this together I can at least drive the car and pray nothing worse happens or pull the car off the road for the second year in a row.
If I do pull the car off the road - I can transfer the blower from my 81 to my 79 track car
Oh the decisons.
Old 07-13-2006, 12:34 AM
hacker-pschorr
You should have been here about 6:30PM.
Lorelei was hiding behind the garage.
Old 07-13-2006, 12:52 AM
Tim Murphy
Tim Murphy's Avatar
And Erik wasn't taking calls.
Tim Murphy is offline
Old 07-13-2006, 02:26 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Considering this looks catastrophic, no real wear, no grunge, just a couple of wedged pieces of the pump housing, teeth look good, I would think you could repair this without a lot of fuss. Is their anything in the pump that didn't originate there? Pull the filter for an autopsy and drain the oil and look for anything else. Flush the pump outlet. Pull the oil lines and the pressure relief valve to drain them and look for stuff. I doesn't sound like the car actually ran at all or at least not more than a couple of seconds when you gave it some gas. If all is clean on the oil autopsy, install new pump, maybe use a one fill flush and let her rip. I can see how one must think foreign body (where is it now?).
Old 07-13-2006, 03:25 AM
mark kibort
mark kibort's Avatar
Not good! But, you are handling it well.
I agree with bill. put the new pump on and clean out the system best you can and have at it. question is , what could have gotten past the filter to the pump? (at least i think thats the path the oil takes) in any event, i think its worth a chance of repair, since its not that hard to replace the pump and after you check the filter what comes out of the pan, off you go! Heck, i was RACING with up to 7 cam sprocket teeth in my pan, and didnt have any issues. still, i think there are 2 teeth floating around as we speak! (and i have no clue where they are, two oil changes later!)
MK
mark kibort is offline
Old 07-13-2006, 03:36 AM
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
It appears the piece in the teeth came from the pump, as Erik stated. If you look hard enough at the last picture, you can see where it broke off. Therefore, nothing appears to have "got by the pump". I would install a new pump, drain/inspect the oil and filter, and if nothing more is found feel good about using that engine again for the time being. JMHO.
Bill51sdr is offline
Old 07-13-2006, 03:55 AM
T_MaX
T_MaX's Avatar
Forgive me if I’m wrong, but doesn’t the oil come up from the pan, than through the oil pump, than into the oil filter?
If I am correct, I would clean all passages from the pump to the filter (including oil cooler lines).
Drain oil and inspect, cut your oil filter apart with a chisel and tin snips and see what you can find in there!
It may not be as bad as it looks!
T_MaX is offline
Old 07-13-2006, 05:58 AM
C.F.
C.F.'s Avatar
Originally Posted by Bill Swift
.............. If you look hard enough at the last picture, you can see where it broke off. Therefore, nothing appears to have "got by the pump". ...............................
ONLY IF the piece that broke off is complete & not missing any little bits.
If complete you could be ok. (see finally below)
If missing a bit , is the filter before or after the pump, is MK or Tmax right ! (its always after on older American V8's)
If the filter is after the pump, does it have a filter bypass system ? eg. if the filter was blocked , oil is diverted straight into the oil ways ,obvoisly no oil pressure in this case so so not applicable, just trying to add to the total picture of maybe's
Finally, what caused the piece to break off ? another foreign body entering the pump ?
Hacker , good luck on what ever path you choose
C.F. is offline
Quick Reply: Has anyone seen an oil pump do this? Seized pump - internally broke apart.
