928 Forum 1978-1995
Sponsored by: 928 Specialists
G-Tech run in 928SP SuperCharger - 0-60 <4.4sec!
Old 06-30-2006, 12:09 PM
  #136
AO
Supercharged
AO's Avatar
Originally Posted by Tony
Found this little tidbit.
The next time you are at the strip set your pitch factor to 0.0 and use this (attached) to figure out the correct pitch factor.
Cool! I can't go for at least another week, but I'll try this as soon as I get back from vacation and get a day at the strip.
Old 06-30-2006, 12:31 PM
  #137
SwayBar
SwayBar's Avatar
This is an Magnuson Superchargerd 03 Zo6.
This guy apparently doesn't know how to drive his car yet as an average driver in a bone-stock C5 Z06 will best all of those numbers. Just like anything, it takes practice to learn how to use a tool effectively.
Just speculating, maybe he couldn't control the wheelspin down low due to the addition of the Magnusson whose forte is low-end power production. A better match for an already strong 405 HP V8 would be a centrifugal which would provide better hook-up at launch, equal mid-range power production, and a much better top-end versus the Magnusson. V8's are torquey by nature versus a 4 or 6 cylinder which can use the additional low-end push.
It's all about putting power to the ground and pushing the car forward as hard as possible without wheelspin for the best time.
Old 06-30-2006, 12:46 PM
  #138
AO
Supercharged
AO's Avatar
I downloaded this one from the G-Tech forum too. Unfortunately his RPM's are screwed up so we can't see if there was much wheel spin or not.
Old 06-30-2006, 12:55 PM
  #139
Kevin Michael
Rocket Pilot
Kevin Michael's Avatar
Not to offend, but a bone stock c-5 z-06 can and will not get below or near those numbers. In fact from his run you can tell he is an experienced pilot. Driven well the stocker will achieve hi 12's at best.
Old 06-30-2006, 02:02 PM
  #140
Larry928GTS
Registered User
Larry928GTS's Avatar
Regardless of whether the guy knew how to drive or not, that's what the car did. (Apparently there sure doesn't seem to be any shortage of Z06 drivers that don't know how to drive their cars then though.) Doesn't matter what he coulda, shoulda, or woulda did, that's what he actually did. Since he posted the data file of that run, apparently he thought it was good enough to have posted those results online for the world to see too.
Any way we can see that run overlayed with Andrew or Tim's runs that were posted earlier?
Old 07-08-2006, 03:01 PM
  #141
AO
Supercharged
AO's Avatar
Got a chance to do a run this morning. Best 0-60 thus far, but I hit the rev limiter in 2nd and it really hurt overall top end. Anyway, pic is below. I'm attaching a link to download the run for people with the G-tech Pass software that want to put into their database.
July 08 - Run 1
June 24 - Run 1
June 20 - Run 1
Old 07-08-2006, 03:41 PM
  #142
IcemanG17
IcemanG17's Avatar
Andrew
Thats gettin there...nice improvement on the 60ft time......1 more tenth to go!! I still think with drag radials, abusive launch & the right weather conditions.....you should be in the low 12's for sure....at closer to 120mph!!
Old 07-08-2006, 06:42 PM
  #143
John Speake
John Speake's Avatar
It would be easy to raise the rpm cutout with the ST. DR could create a new EPROM from the bin file he has for your car, and just post the chip to you.
I thought GTs had a usual rpm limit of 6750rpm ? Any reason why your is set lower ?
Old 07-08-2006, 07:48 PM
  #144
AO
Supercharged
AO's Avatar
Not exactly sure of the logic of why we set it lower... I guess probably just for extra safety margin.
Originally Posted by IcemanG17
Andrew
Yep. It's close. I can smell it. But I think I'll avoid the abusive launch!
Old 07-08-2006, 10:49 PM
  #145
SwayBar
SwayBar's Avatar
I'm not offended, thank you. Nonetheless, there are plenty of posted time-slips backing up what I say. You can certainly think what you want.
Yeah, I'd be pissin' and moanin' too that all a stock 928 can do is 14.xx in the quarter mile. Thank God the superchargers are giving the car some respectability in a straight line!
Like it or not (..and I can tell you do not), Z06 newbs do high 12's, average drivers do low 12's, and the real good ones do high 11's. Stock. How does that song go, ...'can't touch this!' Even with a supercharger!
If I'm in my 928 and a Z06 comes my way, I'll just let his royal highness by...
Can't touch this!
Old 07-08-2006, 11:33 PM
  #146
BC
BC's Avatar
Can't touch this!
I think that a lighter 928 wih go fast goodies enough for 600 crank (not that big of a deal) could give them a good run.
But we are talking about billions of devlopment $$ compared to the 100s of millions or less for the final 928 product.
Old 07-08-2006, 11:51 PM
  #147
pmotts
pmotts's Avatar
I think you are in the wrong Forum. You should feel right at home here.
http://forums.corvetteforum.com/zeroforum?id=49
How about an 11.38 1/4 on stock tires...
http://forums.corvetteforum.com/show....php?t=1360361
Can't touch this!
Old 07-08-2006, 11:53 PM
  #148
Kevin Michael
Rocket Pilot
I have no concern about the zo6. the new ones are awsome though. I am referring pre-05. You could never wring hi 11's out of one of these stock. If you can you should drive for the magz. because their test pilots could'nt pull it off. But it is OK to love your car, just not too much.
Kevin
Old 07-09-2006, 12:21 AM
  #149
pmotts
pmotts's Avatar
Lotsa times here http://forums.corvetteforum.com/show....php?t=1132866
Kevin
Old 07-09-2006, 09:57 AM
  #150
AO
Supercharged
AO's Avatar
Got another run in this morning. Launch wasn't quite as good as the last one, but it's my best ET.
Here's the file for those playing at home. July 09 - run 1
Quick Reply: G-Tech run in 928SP SuperCharger - 0-60 <4.4sec!
