Murf SuperShark - Supercharged US-Spec 1981 completed - fun way to spend a weekend.
#258
Man of many SIGs
[inside conversation] Did you get the audio portion? Someone else I sent it to didn't get that part and thought I just sent the picture. I hope it didn't go out that way to everyone [/private conversation]
#259
Administrator - "Tyson"
Well, I've seen fire shoot out of a tailpipe before. I've never seen a constant burn that looks like an F-14 afterburner. Thank God Rob was filming or we wouldn't know this was happening. This much raw fuel doesn't really show up on the air / fuel gauge. Next time I run on the dyno we are shutting the lights off, could be pretty cool
Needless to say the car is ok, I still have work to do. Nothing positive to report.
I'll post the video as soon as I have it uploaded.
EDIT - here is the video, just the good part![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
PLEASE - RIGHT CLICK & SAVE AS, OTHERWISE IT WILL TAKE A WHILE TO LOAD. I'm sharing this video from my server vs. Google Video to keep the quality as high as possible.
http://www.erik27.com/Fire.wmv
#262
81 US = L-jet
#263
#266
Rennlist Sponsor
Erik,
You sure you didn't sneak a 2008 Ford Super Duty Turbo diesel engine in your 928??
http://www.youtube.com/watch?v=v36MCcRPRTc
Congrats on all the hard work you are doing and the results !!
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
#269
Very funny - did you miss the video?
Now I need to tune the car so that happens on the 79 when I let of the gas going into a corner. Will scare the **** out of those 911's.
Turbo on that thing is bigger than my head....then again so is my supercharger.
I consider this video a PSA as to why you should always film your dyno runs - at least from the *** end.
That same day a 9 second 1,000ish hp drag car blew it's head gasket on the dyno......WOW talk about exciting
Anyway - it's 4AM on a Saturday morning. The end of yet another garage night at Casa De La Murphy (aka, home of Murf928.com).
I wanted to gap my plugs wider since my car was not a happy camper with a .020 plug gap with 2 range colder plugs when cold / cruising. Just to recap the tight plug gap was to "fix" an upper RPM ignition miss under higher boost.
Well, as Z and I went over the game plan for tonights project, he asked about my plug wires. I informed him I took a lot of time to route them with spacers, nice flowing curves etc.... keep the coil wire away from everything....you know, basic engine stuff I already knew but failed to execute when I installed the wires.
When I told Z my coil wire was going up and around at least three plug wires before (when the ignition was missing) he rolled his eyes and said I might have found the problem. I then told him my green wire was mixed up there somwhere as well......so needless to say I'm a dumbass. I'm only sharing this so everyone else out there realizes how important it is to route your plug wires in a neat and orderly fashion. This becomes VERY important at 15 psi. So last nights (or this morning?) multiple redline pulls to 15+ psi with zero missing up top (before it would kick in as early as 4,500rpm).
Now it's time to play with timing to get rid of the blow torch out the tail pipe. It's also still a bit lean up top....enough to get you nervous but not enough to keep your foot out of it
Hey Earnest - how long before my head gaskets blow?
![](http://forums.gottadeal.com/images/smilies/stick_poke.gif)
#270
Road Warrior
nice updates/write up!! that is too cool, btw.. as if a 3k lb missle wasn't enough to scare a 1900lb slug driver.... maybe a halloween mask over the helmet too??
