*UPDATE*HELP car shut off and wont start
I as pulling out of my driveway and put it into gear, gave it a little gas and it just died. Cranks over fine I had some one crank it and I looked and seen there is no spark from coils. I can here 2 relays clicking in fuse box when I turn key. The fuel pump is making no noise when cranking or when I turn key to ON position.
I checked fuses also and wiggled relays.
New fuel pump 500 miles ago.
New TB/WP 50 miles.
Maybe the aftermarket chips I put in 1mile ago?
86.5 man thanks for any advice.
New TB/WP 50 miles.
Uhoh. I was going to say swap the fuel pump relay for the horn relay, but you incriminated yourself with the chip thing. Still, you should probably swap or jump 30-87 on that relay, then the EZK relay, then the LH relay. If that fails, put the original chip back in.
What Bill said...
Also - I would double check for any corrosion or possible bent pin on the LH & EZK connectors.
Fuel pump not running + No spark doesn't sound like a FP relay.
Fleet of Foot
86.5 doesn't have a crank sensor, don't bother. Most likely culprits are LH, EZF, or fuel pump relays. Failing that, go back and put the priginal PROM set back in.
86.5 doesn't have a Hall sensor, but certainly has/needs a crank trigger.
Bob Ball got this right.....a good plan of action when working on your/anybody's car is to immediately go back to the last thing you touched before the car quit.
Hi Guys,
I hate to bring up bad omens but this is exactly how my TB failed on my first 79. I checked everything and finally realized that the cam's were not moving. Good luck, I will pray this is not the problem but you must look.
Thanks,
Frank Barnhill
79 Euro
Thanks,
Frank Barnhill
79 Euro
Well I checked all relays..good no corrosion all worked. Checked all connections to sensors all OK.
Swapped back to old chips...nothing. So I had a friend push me back into the garage and what... it started right up! Now this is weird. The only thing I did when i put it in the garage is put a battery charger on it but it wasnt really that low, Ive started it several times before being even lower. When I pulled it outside the battery was full so thats why I think it might be a coinsidence. No it starts everytime fine. Now Im worried about taking it anywhere.
