12.6 @ 116mph 928 Turbosport 1/4 run....ruined!
#31
Under the Lift
Originally Posted by moon928
Mark - it sounds like a beast. I cant wait to see more of the video.
#33
Under the Lift
It looks on the video like Mark sat at start after the green light. Sure enough - reaction time 1.44 seconds. Mark?
#34
LSD is probably the biggest difference. (and sure, the tires too!)
I dont know how you can do it with an open diff. good job. anyway, z06s dont have very short gears. (or closer for that matter) their actually tall just like a 2.2 or a 2.75 928, with speeds in 1st 2nd and 3rd of 57, 85 and 116mph (and 4th at 155mph) 5th and 6th are just overdrive gears!
so yes, i think you are on saying the same thing i have been during my racing of the 928. they can be just as fast, but for a lot less money.
mk
mk
Originally Posted by MarkRobinson
Zo6's have short gears and 325mm rear tires too (& LSD) & lots of low end torque that's easily modulated by the pedal. Then again, it's a 70k Chevy (pass).
If I can spend 6k on a turbosystem & 4k on wheels & tires that gets me close to a Z06's performance, I'm happy.
#35
Yep, I sat on the light, though, the NOS-equipped Transam next to me dialed in a 12.23 & almost did it. I can't compete with his 60' time in my stock configuration, so I decided not to try & to concentrate on my launch. Weee.
The turbo kit will bolt up to all 928's, I just haven't had the time to adapt it to other models besides my own. I figure the CIS (Lance) and the S4 will go first, but the '80-84 cars will quickly follow.
#36
well Us CiS guys will need carls cis intake adpater. and maybe his FES kit for those who just want to bolt and go. 5 psi to be safe with out fueling mods. I'm working on a EFI for my Cis. I know these fuel systems can support 400rwhp via turbo ask the 911 cis turbo guys putting down 380rwhp. but i do want plug and play. Our cis will just suck down fuel. i Know For sure the Cis will take the drivetrain and traction to it limits.
#37
Under the Lift
#38
Captain Obvious
Super User
Super User
Sorry Bill, that's not how it works!
The clock doesn't trart until you start to move. You can sit at the line for 5 min after the green and the clock will not start until you cross the start line. In a non-pro tree setup a perfect reaction time is 0.500sec. Anything less is a red light.
#39
I dont recall them counting the timer until you react: pass the gate. I could sit there for 20s I think & still run a 12 second quarter. A lot of it is about your 60' time: time to get 0 to 60', or "the hole-shot". Automatics with NOS are quite good at this, wider tires help too. my 60' was pretty bad, and my reaction time was a result of me trying to stage my rpms better before dropping the clutch: which I did too high (see the smoke off the left tire about 20' down the track?)
#40
Under the Lift
Err, OK. I thought reaction time was a key element. My buddy focuses a lot on reaction time. I recall he said below 0.6 and you are DQ'd at his track (in Hawaii). He shoots for low 0.6X.
#43
The ZO6 has these final ratios 1st 10.16, 2nd 7.08, 3rd 4.89, 4th 3.42, 5th 2.43 and 6th 1.95.
