Who's got the coolest wheels? (gimme pix!)
#271
Afshin,
No rolling required.
The fronts are almost an exact match of the size of the wheel on the '89 928 GT (factory 8 inch wide ET 60 - 16 inch vs this one which is 8 inch wide ET 57 - 18 inch). I have 235's on the front vs factory size 225. Nice fit.
The rears are 10 inch with ET 58 with 265 rubber. Lots of space on the inside and outside. I should be able to go to a 295 when the 265's wear out. Now the GT has a slightly rolled rear fender from the factory, but there is no doubt that with 265's they would fit on an S4 body. I would have to believe that even 285 or 295 would fit on an S4 body, but I can't be sure.
#274
...and a set im looking at today.
Plus at my "experience level" and the weight of my current wheels i really would notice the difference..
18x8 fronts w/225/40-18 Continental SC2
18x11 rears w/295/30-18 Conti SC2
#276
Originally Posted by Chris Lockhart
Thanks for the help Tony. Are those the hollow spokes??? They look great on a 928.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#277
Originally Posted by Tony
...and a set im looking at today. ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
I do like the turbo-hollow spoke look on the 928....might be a hard fit with an 11" 45mm wheel in the rear....might have to roll the fenders a touch, but then you could run 305+ tires on the rear!! That would be SWEET!! You can get aftermarket copies in an 18X8 50mm and 18x10 65mm that should fit no problem...really cheap too $739 a set on ebay!
#278
http://cgi.ebay.com/ebaymotors/18x8-...spagenameZWDVW
I assume these are the ones your talking about?
If i wanted the solid spoke 10s id just get them from 928intl..they have them also.
If i can get 11's in the back id rather do that...I WILL be rolling a fender, thats for sure. Plus the ones im looking at are with tires 295s...less hassle at this point
#279
Tony - Those also come in aftermarket 65mm 10s. Heavier - over 30 pounds, but they may fit up front (I haven't had a chance to try the hollow spokes I have in 10/65mm)
#281
If i can get 11's in the back id rather do that...I WILL be rolling a fender, thats for sure. Plus the ones im looking at are with tires 295s...less hassle at this point![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Those are the wheels....just cheaper from this source
http://cgi.ebay.com/ebaymotors/18-8-...QQcmdZViewItem
Only $739 plus shipping.....hmm how much lighter are the factory hollowspokes?
#282
Those are the non-oem wheels. Much heavier (30 pounds for the rear 10"), and those also come in hollow spokes *8 and 11*, and for just over 1k.
The thing is though - can you feel a heavier wheel?
#283
my 18" rear RIVA with the Kuhmo 265s and center cap on it weighed 57 lbs...with the TOYA RA1 from Mark it weighed 54 lbs.
I will say that when i went from the stock 16 inch slots to the 18" Riva when the car was NA, i could feel the difference in accerlation.
#284
Well in that case I say that the OEM 11s for the rear 45mm (some rolling) and the 10" fronts with 265 (some rolling on the front) would be very nice.
It should be like a slot car.
#285
Road Warrior
wider/lower profile shoes do feel like a slot car in the canyons, etc. except in the rain- the wider meat hydroplanes a LOT easier, so I don't even bother pulling my old gal out if there are any clouds on the horizon anymore.
