928 Forum 1978-1995
Sponsored by: 928 Specialists
Anchor Motor Mounts $18 each
Old 01-30-2006, 02:23 PM
  #61
ROG100
Basic Sponsor
ROG100's Avatar
Doc,
Yes I can let me know when.
We are burying electric cables on Saturday don't need no stinking compressor.
Had you something else in mind?
Roger
Old 01-30-2006, 03:12 PM
  #62
docmirror
Shameful Thread Killer
docmirror's Avatar
Originally Posted by ROG100
Doc,
Roger
MM job on the Cassisrot? Nes pa?
Doc
Old 01-30-2006, 03:15 PM
  #63
ROG100
Basic Sponsor
ROG100's Avatar
No not yet - maybe the week after.
Rog
Old 01-30-2006, 03:16 PM
  #64
ROG100
Basic Sponsor
ROG100's Avatar
I need main power to the garage first so some of my friends can use a compressor when wrenching. Nes Pa!
Rog
Old 01-30-2006, 03:21 PM
  #65
docmirror
docmirror's Avatar
Okay, I'm out west Feb 8-17. Cya Sat.
Doc
Old 01-30-2006, 06:42 PM
  #66
BC
BC's Avatar
I bought some from Rock auto, but they werelike 35 then. I bought the liquid filled ones.
The Porsche ones on the original cars did not last 15 years. They didn't last 10 years. The fact is that nobody noticed because again its a slow degrade of performance - like your shocks. Shocks degrade slowly, and nobody notices until someone drives a newer car, or the same car with new shocks.
Old 01-30-2006, 06:52 PM
  #67
ROG100
Basic Sponsor
ROG100's Avatar
See the attached picture of the four MM I received from RockAuto.
I did not look closely until this morning and realized there were a lot of differences.
RockAuto have the picture and I have returned all four to them.
They are researching why so many different connotations with Anchor and will get back to me.
Spoke with the tech expert at Anchor.
They use 2 part numbers in house.
2698 is hydraulic.
2698SR is solid (Solid Rubber)
No conclusions as yet but whatch this space.
All the MM we have fitted were the hydraulic USA ones.
Old 01-30-2006, 08:12 PM
  #68
H2
H2's Avatar
OK...which one do we need? And how do we make sure we get what we order...? The salespeople just punch a number into the compter,
Harvey
Old 01-30-2006, 08:22 PM
  #69
ROG100
Basic Sponsor
ROG100's Avatar
"No conclusions as yet but watch this space".
Old 01-31-2006, 08:29 PM
  #70
Schocki
Schocki's Avatar
Question to the experts: I send this Anchor mount (Made in USA) to Germany. The inner rubber came off (picture). I think the mount is fine and this is a piece of rubber that is being crushed when they press the mount together.
Old 01-31-2006, 08:50 PM
  #71
Garth S
Garth S's Avatar
Originally Posted by Schocki
..... The inner rubber came off (picture). I think the mount is fine and this is a piece of rubber that is being crushed when they press the mount together.....
Agreed: this appears to be excess rubber extruded ('flashing') during manufacturing - it is not structural/important to correct function.
Roger, more trivia - did all four mounts have the same thread pitch/stud size? Mine were a reasonably standard M12x1.75 ( Porsche uses a M12x1.5), but IIRC some reported sourcing SAE coarse thread nuts to fit the studs.
Old 01-31-2006, 09:02 PM
  #72
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
I also got several pin configurations from Rock Auto. After finally installing two of them, I concluded that the pins didn't matter that much. I forget but you would ideally have one pin at the top (or bottom) only. A hack saw can cut off extra pin. If you don't get any pins you can torque the hell out of the first side you tighten on the MM (top I think).
When you get there it will not be that hard especially compared to wrestling the cross member back in place.
Good luck,
Dave McK.
Old 01-31-2006, 09:20 PM
  #73
ROG100
Basic Sponsor
ROG100's Avatar
Garth,
Good point - never checked that as the others were the metric size.
I will check the new ones when they arrive.
Replacements are on the way.
Both Anchor and RockAuto are responding to me and taking the issue seriously.
I will update when I receive the replacements.
Best,
Roger
Old 01-31-2006, 09:21 PM
  #74
ROG100
Basic Sponsor
ROG100's Avatar
Schocki,
Garth is dead right that is Flashing.
No problem.
Roger
Old 01-31-2006, 10:08 PM
  #75
Schocki
Schocki's Avatar
Thanks guys!!!
Quick Reply: Anchor Motor Mounts $18 each
