Anchor Motor Mounts $18 each
#46
Does anyone know what the actual height difference is between a new Porsche mount and one of the solid (non-hydraulic) mounts that are being used? I'm assuming that the new non-Porsche mounts are still taller than collapsed Porsche ones, even if no washers are used. I've seen people mention using washers to make up the difference in height, but how much is that difference?
#47
928 Collector
when they are flat it makes zero diff. Plus the stock ones do not sit at exactly the ame height, they are rubber with hydrauic fluid (probably water) ... so .... the anchor solids I've had on my S4 for 6 years are perfect.
#48
Originally Posted by ROG100
Harvey,
You obviously did not read my post on this tread about the quality of Indian manufactured goods.
Have you ever been there - I have and there engineering quality is excellent.
They tend to do things better than the US or UK because they know that anything less and nobody will buy.
There operators tend to have degrees in engineering and know what they are doing.
Do not be to quick to bash something you don't have factual evidence to back up.
I have no problem using the anchor mounts if they are from India.
I would lay money down that they are probably better than the USA made units.
Sorry about the rant but we Americans are to quick to diss other nations.
Roger
Roger
I frequently meet with fairly high level computing professionals and I'm amazed at where the Indians are technologically. You're right, the world's changing....however, keeping up is difficult. I'll concede that IF quality control is tight, the Indian motor mounts will be good. If not, they'll crumble in a few years.
No matter where they're made I would prefer solid mounts in my German 928. BTW, German Quality is nothing to be sneezed at. Only problem I see there is that the last Bosch parts I bought were actually made in Mexico, Brazil, and Bangladesh...anywhere but Germany. The parts appeared to be good, and I assume built to Bosch standards..but the cardboard boxes were obviously of less quality. In today's world, it's hard to tell what's best and what's not. If the part is of the quality of the boxes, I'm in trouble.
Keep truckin'
Harvey
#49
Basic Sponsor
Hi Harvey,
I'm sorry I was on a rant.
But basically the point stands.
I have received my MM and some are of Indian manufacture and one is USA.
As an American I hate to admit but the Indian ones are better.
Pictures to follow.
Roger
Pictures to follow.
Roger
#50
Under the Lift
I went along with Harvey's reasoning when I did my mounts. The originals lasted 15 years, and actually weren't bad. I did them as a WYAIT task. The Anchor idea was new, and still is, relatively speaking. Yes, there had been some premature failures on the Porsche mounts, but the numerator is quite small relative to large denominator. Mine are still like new. I understand how $18 could temp just about anyone. So, I don't blame you guys, but Harvey's logic is not erroneous.
#53
Any more would have been too much, for the right air tube is a very tight squeeze under the crossbar. Installation without the washers would have been fine.
#54
Basic Sponsor
Pictures of the two mounts side by side.
The cad plated (gold color) unit is made in India.
Notice how the Indians have gone to the trouble of adding the cad plate and also thread protection.
The unit from India has the extra pin. Why I do not know.
I will put the Indian units on the Cassirot 87 I just bought for a friend.
#56
Roger,
I will as soon as the arrive
BTW The Made in India mounts that I had in my hands at the autozone did not look like these on your pictures. They were all black and painted and looked exactly like the Made in USA that we used so far.
#57
928 Collector
About mount height:
If they were both the same height, what would they be when compressed? Wouldn't that mesurement be entirely different for liquid-filled vs solid units?
#58
Owns the Streets
Needs Camber
Needs Camber
Guess it's time to find somone with a press.
300lbs clamping force? 500lb plus for a fluid laden assembled motor?
A fluid will disperse pressure equally on all sides. That's what
I'm guessing occurs with the Hydraulic filling.
Vertical load in mount is partially dispersed to the side expansion
of the rubber.
Solid mount compressed will bulge less and differently than the
hydraulic one as the rubber molecules stretch and exert opposing
force to the bulging.
Did they know about silicone fluid back in the 70's.
Just hypothesizing.
The Oh-fficial Porsche mount makes the V8 lump very smooth.
Especially at the lower revs. Stalled the motor a few times on
clutch take-up as I can no longer feel any reaction from the motor.
Guess that's good for dentist's wives car.
Ernest(NYC)
of the rubber.
Just hypothesizing.
Ernest(NYC)
Originally Posted by heinrich
About mount height:
#59
Basic Sponsor
Well this topic is now getting more interesting.
I decided to talk to Anchor Industries technical support.
My main reasoning being to track down the physical differences between the units.
1) Two pins v one pin.
2) One pin on the metal end v one pin on the rubber end.
3) Hydraulic v Solid.
Here's what I found out.
Anchor manufacture themselves and use a sub contractor (probably the Indian facility).
They are both solid and hydraulic.
How do you tell - shake them - the ones that are liquid filled are Hydraulic - duuuuur!
The pins are where it gets interesting.
I noticed that one of the units I just received has no pin on the metal end of the MM only the rubber end. We need a pin on the metal end for our cars.
RockAuto are now really confused as there are so many permeations based on one part number 2698.
I am waiting for Anchor to confirm that there are indeed different part numbers.
Update later
Update later
#60
Shameful Thread Killer
You guys kill me. All these wasted electrons on an $18 part that lasts 6+ years. Just go get the Anchor from Rock, use a single fender washer under it, grind the second nub if needed, and use nylock nuts.
Yes, the job is messy, no it's not hard to do if you have a few pry bars, there is excellent documentation, and the results are great.
Rog, see you Sat, can you pick me up from Roanoke airport near the fuel pumps? Is your compressor functioning?
Doc
Doc
