928 Forum 1978-1995
Sponsored by: 928 Specialists
Drilled Crank Thoughts...
Old 01-10-2008, 06:28 PM
  #286
largecar379
largecar379's Avatar
Originally Posted by 6.0-928S
Every Race Hemi I've ever had uses a swinging oil pickup. (as well as every one I've ever seen at the strip) They work great. Hemis spin up to 9000 rpm with swinging pickups. There is no friction issue & the pickup follows the oil so as long as the pan is baffled the pickup is always in the oil. I've thought about putting one in my 928 but I'm still tied up with my ITB setup so I put the pickup on the back burner. But it will work.
Hammer
NO Sh**!!!!!
leave it to another MOPAR guy to input some thing (that we've worked on for decades) that could help greatly in the quest for better oiling.......
(wish I still had my '64 SS/DA car........)
Old 01-10-2008, 06:30 PM
  #287
6.0-928S
6.0-928S's Avatar
Old 01-10-2008, 06:35 PM
  #288
largecar379
you could just drop one of these in there.......
less weight
636 CI
1120 hp
930 torque
about the same cost as a 928 stroker...........and it will fit.
(Why didn't I think of this sooner...........?)
--Russ
Old 01-10-2008, 06:43 PM
  #289
BC
BC's Avatar
A 928 stroker is about 10k 15k if you want to do it Louie's way with ITB. How much is that motor? And I can't see where I plug in. People under 40 don't know what a float or Jet IS, let alone how to tune a car with a carb.
Old 01-10-2008, 06:54 PM
  #290
marton
marton's Avatar
Stan posted
HTML Code:
has been speculated elsewhere that the 2/6 failure was
uncommon (perhaps unheard of) on the pre 5L motors
I also heard it said that was only unheard of on pre-83 motors because they changed the sump design & oil pick up on 83 & later (to save cost?).
But there are contrary posts (like JimB) to say also 2/6 problems on early motors like 4.5. I assume Jim did check the oil level frequently
Marton
  #291
largecar379
I wasn't really serious about it.....but it is an alternative. the engine pictured runs on (at least) 116 octane race gas, has a CR of nearly 16:1, so it really isn't a street engine at all. the street version is a little more tame, with only 605 ci/10.5:1 CR, 830 hp and 780 torque......
or you can get a wedge engine for a little less money, but about the same performance specs.
plugging it in is probably no more difficult that the Renegade/SBC kits......
I've done the price comparisons back and forth for some time now, and it's just a matter of keeping "Porsche" or not.
--Russ
Old 01-10-2008, 07:03 PM
  #292
6.0-928S
6.0-928S's Avatar
That's OK Brendan, as you know, I don't know how to 'shark tune' my stroker w/ITBs either, but I could tune a carbureted (2 X 4 crossram) Race Hemi in my sleep.
Hammer
Old 01-10-2008, 07:09 PM
  #293
Charley B
Charley B's Avatar
Give me a full race Ford flathead V8 with twin Strombergs and I'll have it singing "Take me out to the ballgame" in short order.
Old 01-10-2008, 07:11 PM
  #294
6.0-928S
6.0-928S's Avatar
That's another sweeeet sound!
Of course that would also fit in a 928!
Hammer
Old 01-10-2008, 09:10 PM
  #295
Daniel Dudley
Daniel Dudley's Avatar
Originally Posted by Stan.Shaw@Excell.Net
Daniel,
clearly Taylor machine is the shop of choice now. I had a crank drilled there, but it went with some other parts I sold when I committed myself to the stroker project build.
Anyone want a good 5L crank to get drilled, please let me know. I would like to get another stroker crank to build a motor for the GT too
A lot of good info has come from you posting this thread. Sorry if I implied something that was not intended to be insulting.
Old 01-10-2008, 09:59 PM
  #296
Stan.Shaw@Excell.Net's Avatar
Hi Daniel,
Sorry if you thought I was offended. No offense taken at all.
I appreciate yours, and others, comments. Often a different perspective will shed light on something.
Seriously though, if you saw my garage, you wouldn't suggest that I should get another project going. My problem is too many already. I could have worse habits, and I keep my car addiction costs separate from the household budget, so my wife tolerates my foolishness.
Old 01-10-2008, 10:10 PM
  #297
I know this is an offhand comment, but this is basically the cost of the parts for a stroker build. I know many here will do their own motor work, so your estimate is reasonable for many, but for anyone intending to pay labor costs, the number could easily double, right? Of course if you forgo 968 valved heads, the ITBs, drysump, you can save money.
Off the top of my head, (these are very round numbers):
$3k for a crank
$1.5k for rods
$1k for used 968 pistons then coated
$1k for block boring and lapping
$4k for head work with 968 valves (labor included here)
$1.5k for custom cams
$2k for exhaust
For a track car, some other upgrades:
$1.5k for clutch
$3k for ITB
$3.5k for a GT trans.
$3k for drysump
$3k for custom electronics (Motec, DTA, etc)
$1k fuel pump upgrades
Assembly labor for all not included, except the heads.
I better stop before I hurt myself
Old 01-10-2008, 10:16 PM
  #298
atb
atb's Avatar
I'll up you a pair of Arduns, sitting under a 371 Jimmy topped with a six pack of Strombergs singing "Play Misty for Me" and I'll even leave the Uni-syn on the bench.
Old 01-10-2008, 10:52 PM
  #299
Charley B
Charley B's Avatar
Old 01-11-2008, 02:05 AM
  #300
BC
BC's Avatar
Hammer
Quick Reply: Drilled Crank Thoughts...
