928 Forum 1978-1995
Sponsored by: 928 Specialists
Delco Alternator Conversion
Old 01-01-2006, 03:49 PM
FlyingDog
FlyingDog's Avatar
Does the stock alternator cover fit?
Old 01-01-2006, 03:52 PM
toofast928
toofast928's Avatar
No, the cover is only for the Paris Rhone alternator.
Old 01-01-2006, 03:54 PM
John Struthers
User
John Struthers's Avatar
Hell.
If it'll fit ...use contact glue, liquid nails, silicon and roll.
Old 01-02-2006, 01:22 AM
wg928
wg928's Avatar
THANK YOUUUUUUUU SIR. WOOHEEEEE I'M ON IT---- YESSSSSSSSSS!
Old 01-02-2006, 04:36 AM
SharkSkin
SharkSkin's Avatar
Originally Posted by toofast928
The GM pulley was ribbed, I changed over to V style.
Where did you source the pulley?
Old 01-02-2006, 02:41 PM
borland
borland's Avatar
That Delco looks to be soon clogged with grease and thus overheating.
Why not rebuild the old one? Just source the parts here:
http://www.wai-wetherill.com/products/bom.cfm
Enter the "AL170X" in the "bill of materials" part block (for the later model Bosch alternator). Then,
order your parts from the local autoparts store, or here:
http://nationsautoelectric.com/catalog.html
Most only require moderate cleaning, new bearings, and maybe brushes. Then you won't defeat the climate control's outside air sensor. The original will last much longer with the original air duct installed.
borland
90' S4, Slate Metallic
Old 01-02-2006, 03:43 PM
heinrich
928 Collector
heinrich's Avatar
Borland, thanks for that, too
Old 01-02-2006, 06:18 PM
BrianG
BrianG's Avatar
Porsche OEM wiring to the back of the Bosch or Paris Rome alternator is one eye lug consisting of two red wires >> Battery charge.
The other connection is voltage sense/exciter. Green wire I think.
The Delco connections are:
Large battery wire to Batt terminal.
Red wire of Painless wire adapter to batt terminal.
White wire of Painless adapter to be spliced into Porsche harness, Green wire.
Painless Wire Adapter P/N 30707
I'm certainly open to correction here, but my understanding of this 3 wire Delco alternator is that the big lug supplies the charge current (to the battery). The red wire provides the alternator field coils with power and the white wire supplies the idiot light signal.
If this is the case, the red wire on the Painless adapter should be fed power through an ignition-switched supply. If that wire is connected directly to the battery, as proposed, the field coils will always be energized. This will be a constant draw on the battery and will eventually kill the battery if the car is not started fairly regularly to replenish the charge.
Am I wrong??
Old 01-02-2006, 09:35 PM
toofast928
toofast928's Avatar
This should help:
http://oljeep.com/gw/alt/edge_Alternator_Theory.html
http://www.alternatorparts.com/
Old 01-02-2006, 11:22 PM
Barry Johnson
Barry Johnson's Avatar
Holy crap, thats awesome! That will be perfect for all of us big stereo guys... Thanks man!
Old 01-02-2006, 11:45 PM
Normy
Normy's Avatar
That's great, a solution to a problem on the cheap- kind of like me using my 928 to go to the thrift store or something. I'm surprised as well- I think I heard talk of 140 watts!
So what about the big 3-?
N?
Old 01-03-2006, 12:40 AM
toofast928
toofast928's Avatar
That what gets me Normy.
All these years a kit could easy have been made up and sold for lot more. The Delco fits nice and produces steady voltage that the never Bosch could maintain.
Imagine 14.2 volts at idle! A/C on, driving at night (halogen headlamps), 2 amps pounding bass, 8"cooling fan on constantly.....
Old 01-03-2006, 12:48 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Compared to what the 928s came with, the Delco alternator sounds like a supperior product .
Old 01-03-2006, 12:50 AM
Normy
Normy's Avatar
[Sorry, my stereo pounds nothing; In fact it kind of sits there, and occasionally interferes with me hearing my engine sound...]
N!
Old 01-03-2006, 01:03 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Normy?!?!?!?!?! did you post this tread in the wrong place?
Quick Reply: Delco Alternator Conversion
