928 Forum 1978-1995
Sponsored by: 928 Specialists
DOOR Not Opening from outside
Old 12-09-2005, 05:08 PM
surgiblade
surgiblade's Avatar
Default DOOR Not Opening from outside
Lets see-
Replaced the wheel with a MOMO, covered the dash in leather, refinished the outside, bought sheepskins, fixed the A/C, and a nuisancesome short- Now
The drivers side door does not open from the outside- I can pull on it several times and then it opened, but now zilch.
Any advice and wisdom greatly appreciated !
Old 12-09-2005, 05:16 PM
Big Dave
928 Engine Re-Re-Rebuild Specialist
Big Dave's Avatar
You're not going to like the answer....
http://sis125.berkeley.edu/928/wk-door-handle.html
Old 12-09-2005, 06:24 PM
perrys4
The Lady's Man
perrys4's Avatar
I just did the hinge replacement and it is not that bad. That is what is wrong. My symptom exactly.
Old 12-10-2005, 12:02 AM
surgiblade
surgiblade's Avatar
Thanks much Perry and Dave-
Any suggestions as to where to go in East Bay, SF area to get it done ?
Mike
Old 12-10-2005, 12:04 AM
928drvr86.5
928drvr86.5's Avatar
time to put that surgiblade to work.
Old 12-10-2005, 01:17 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Mike:
Get the part from your 928 parts supplier. When you say you door handle is broken, they will know what you need. Bring the part over. Brian just did his, so we'll get him to show us how it's done.
Old 12-10-2005, 01:20 AM
surgiblade
surgiblade's Avatar
Will do- Thanks again Bill- will get from DEVEK-
Mike
Old 12-10-2005, 01:22 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Mike: Call them tomorrow. I should be over there and can pick it up and we can install it Sunday, if Brian is around.
Old 12-15-2005, 02:50 AM
surgiblade
surgiblade's Avatar
It is late- 22:50-
I finally got the necessary part to fix my non opening driver's side door from DEVEK and NOW
The drivers door works ! Why ?? Why did it not previously ::
Still think it needs fixing but now I can begin to understand why people ascribe personalities to their cars .
Mike
Old 12-15-2005, 05:05 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Mike:
Uh, wait a minute...If it's working again, then the pot metal part was not broken but something is out of adjustment/loose. Come over this weekend and we can take a look. Hold on to the pot metal part - you will need it sometime sooner or later. You're building a little emergency spare parts supply.
Old 12-15-2005, 11:40 AM
marton
marton's Avatar
Does sound like something on the door handle assembly is loose, not broken. I changed mine last year, not difficult just takes a long time because of the limited access - you also have to keep moving the window glass up and down to access the different bits. I also took the opportunity to throw away the big "anti-theft" steel plate, it must weigh a couple of pounds.
if you want to practice first, choose a room at home, cut a 3inch by 1inch slot in the door and then decorate the room through the slot.
Marton
Old 12-15-2005, 12:07 PM
perrys4
The Lady's Man
perrys4's Avatar
I think they crack and once in a while catch just right and work. Mine felt odd for a while and would not catch occasionally.
Old 12-15-2005, 12:45 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Mike: In light of Perry's note, bring the part too.
Old 12-16-2005, 03:10 PM
IcemanG17
IcemanG17's Avatar
Mike
Thats odd...but it does sound like the door handle....I'm out of town until monday...I do have a bunch of days off after the holiday to help out too! Its a real PITA...but can be done in a few hours!
Old 12-16-2005, 07:02 PM
macreel
macreel's Avatar
Mike... no doubt Bill & Perry have it right. My left side handle
was 'hokey' for a year before it broke. Pulling up on the
foremost end of the handle opened the door but the aft
end was ineffective. That's where the crack developed
and eventually broke the potmetal.
Be sure to check the part #; left & right are different (left =
928.537.063.04), assuming it is the same part we all know
and love.
G'luck.
Quick Reply: DOOR Not Opening from outside
