928 Forum 1978-1995
Sponsored by: 928 Specialists
The Twin Screw Thread
Old 11-02-2016, 05:14 PM
  #2656
hans14914
hans14914's Avatar
Originally Posted by V2Rocket
What are you going to do for injector bosses?
They are in the upper portion of the manifold. They are designed for the extend length EV14 Injectors used on the GT3, and are shrouded above the port.
Old 11-03-2016, 10:13 AM
  #2657
Chris Lockhart
Chris Lockhart's Avatar
Originally Posted by davek9
Thanks Hans for the reply, good to know.
Given the Cost, I'll run w/ what I have and try to do updates from what others have learned over time and proven to work well for Andy's system.
From what I have read the intake sealing can be a bit touchy to get right, and the Oil breather / filler on the one I removed only had a plate w/ an elbow (no baffle) installed, so I'm thinking I need to address that.
Once I clean up the heads and V, I'll start looking at how to address those two things.
Chris I'll keep you in mind if things change, thank you
Dave
Thanks Dave. :-)
Old 11-04-2016, 02:14 PM
  #2658
hans14914
hans14914's Avatar
First take on the sheetmetal lower pans. It looks really good, maybe some room for a little tweaking, but definitely on the right track. Looks how well it lines up to the internal radii.
Looking forward to dropping this on the test car tomorrow and checking all the block clearances.
Old 11-04-2016, 04:09 PM
  #2659
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Art. Pure art.
Old 11-04-2016, 09:55 PM
  #2660
RennPartsDirect
Former Vendor
RennPartsDirect's Avatar
Originally Posted by Mongo
Art. Pure art.
Well executed for sure... That lower formed piece came out nice.
Old 11-07-2016, 10:34 AM
  #2661
Chris Lockhart
OMG that is beautiful!! Another beautiful piece that's a shame it'll be hidden.
Old 11-07-2016, 12:30 PM
  #2662
hans14914
hans14914's Avatar
Thanks everyone for your support.
Revisions, revisions, revisions. The test part came in, and I saw some areas for improvement. Hoping the second revision part will here when I get back from Third Coast, along with the machined upper parts so I can show you guys a real mockup.
I am adding a joggle in the vertical side walls. This will add strength to the part, and give some more clearance for the casting bosses towards the back of the valley. I am printing a test cross section part with the joggle, and also with the floor raised a bit for additional clearance/heat rejection on the pan bottom.
These changes give me flexibility on the thermal management. I am still on the fence on creating a template and cutting adhesive mat to adhere to the pan, or masking and spraying with a ceramic coating (exterior only).
If the test part fits and passes the clearance test, I am going to move forward with this revision on all the production sheetmetal lowers while I finish selection of the heat insulation media.
Old 11-15-2016, 01:37 PM
  #2663
hans14914
hans14914's Avatar
To keep everyone in the loop, the test batch of custom intercooler fittings are in. There is a double o-ring interface at both the intercooler end-tank and the rear wall of the intake manifold.
The tank side is radiused for flow, and the fitting end is machines to accept Jiffy-Tite Pro-Compact Series60 fittings. I will be using the -12 pushlock quick connect fittings for one-handed toolless installation of .75" equivalent hose. This system should flow really well.
Pictures of the end tank are without the freezeplugs installed for easier viewing.
The second set of photos shows the printed jig for pressure testing the cores without the manifold.
Finally, attaching some pictures of the upper portion of the intake manifold after the first side was machined.
Hoping to have all the machined parts in this week.
Old 11-15-2016, 02:33 PM
  #2664
Chris Lockhart
Works of art!
Old 11-15-2016, 04:39 PM
  #2665
AO
Supercharged
AO's Avatar
Super cool, Hans! Nice work.
Old 11-15-2016, 11:33 PM
  #2666
BrianG
BrianG's Avatar
Originally Posted by Chris Lockhart
Brian, mine was leaking, but when I tore it all down to do the head gaskets it turned out to be external.
Andrew Olson had a leak on his heat exchanger but his is the later Dave Roberts/928SP version.
I did a pressure test on mine in the kitchen sink with 5 psi (IIRC) and it looked ok, but I just don't trust that because I couldn't fit it all the way in at once. I really would like to have a shop do a good test to ease my mind.
Are you having issues that leads you to believe yours is leaking?
Chris, I am losing coolant as well, and I can't see any external leakage. I am planning a manifold-only intercooler pressure leakdown test, at 5 psi as suggested by Colin Jensan. I realize that that will still leave a couple of possibilities about the acutal source of the leak, but it won't leave any possibilities regarding pulling the manifold.
Originally Posted by hans14914
I should be able to help you with the oil breather plate. I think that should be interchangeable between my design and your Keel kit. I will just go ahead and order a couple spares when I get them machined.
Please make a couple of these, Hans. It's a problem that I'm having as well.
Old 11-16-2016, 10:13 AM
  #2667
Chris Lockhart
Well let me know how it turns out. I hope it's not in/under the manifold.
Old 11-16-2016, 11:08 AM
  #2668
hans14914
hans14914's Avatar
You could always look at it as free methanol injection....
Old 11-16-2016, 05:02 PM
  #2669
Imo000
Captain Obvious
Super User
Imo000's Avatar
Chris, I am losing coolant as well, and I can't see any external leakage. I am planning a manifold-only intercooler pressure leakdown test, at 5 psi as suggested by Colin Jensan. I realize that that will still leave a couple of possibilities about the acutal source of the leak, but it won't leave any possibilities regarding pulling the manifold..........
If you access to a borescope, pull some spark plugs and have a look. The piston tops should be squeaky clean.
Old 11-23-2016, 11:33 AM
  #2670
hans14914
hans14914's Avatar
More progress pics from a manifold upper machined on the second side. Getting closer. Intercooler should be here on Friday for test fit too.
Quick Reply: The Twin Screw Thread
