Invitation - Timing Belt Party
#46
Ok, I'll get the coolant and brake cleaner and I have all the other stuff that Bill mentioned. Count me in as a wrench turner!!!
Also, I've found little hands (like mine) are often helpful (ok guys, don't get dirty on me here - you know what I mean)
I better review the TB guide - again!
#47
Beth, maybe you could consider a salad, even though Ron's not coming.
My favorite cookies are the Costco chocolate chunk, but if you get those you better hide most of them. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I'll bring my weed wacker and other fuse panel/electrical-related tools.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Also, you will need to catch splashing coolant, whether you drain the block or not.... be sure you have a suitable container to catch it. I found a 5 gallon bucket sufficient when draining the block, but if you just let it spill when pulling the WP you will need a much wider container.
Some Anti-seize would be a good thing to have on hand as well.
#51
Oh, be sure to get some distilled water too. If changing coolant type get about 8 gallons; that way you can flush the system a few times with tap water, once with distilled water, then fill appropriately. If you just want to change coolant 4 gallons is plenty. Reccomendations are all over the map; I used 1 gal. DexCool, one bottle Redline water wetter and ~3 gallons distilled water.
#58
Hey Dave - no word from Nicole yet so can you bring yours? I'd rather end up with 2 sets than none.
Of course "T", you can attend. The more the merrier!!!
No Broken Water Pump Bolts, No Broken Water Pump Bolts, No Broken Water Pump Bolts . . . . . . .
I think next week I'll take another head count - need to make sure there's enough food and drinks, can't let you guys get hungry . . . . . .
#59
So here is the list of parts in my "TB replacement kit" by Susan at Devek:
Water Pump (new - not reconditioned)
Waterpump Gasket
Timing Belt
Inner piston seal
boot clamp
oil pump o-ring
front main seal
oil pump bolt o-ring (3 of these)
dipstick seal
belt tension wire
gasket, tensioner housing
tensioner cap
tensioner roller (2 of these but different part #'s)
bearing for 928.105.067.00/01
bushing (2 of these)
So I hope (and pray) you guys know what all this stuff is. . . . . .
Waterpump Gasket
Timing Belt
Inner piston seal
boot clamp
oil pump o-ring
front main seal
dipstick seal
belt tension wire
tensioner cap
#60
Cottage Industry Sponsor
Hi Beth:
I can certainly bring my fender covers. But it might be a good idea to remind me the day before the party...
Also, did we set a time? I know you guys like to start right after midnight. Remember that Dave and I have between 1.5 and 2 hours driving time to your house (depending on how badly we want speeding tickets)
