Stalling when cold
1979 CIS. No O2 sensor.
As fall is here, I am addressing a cold start issue. The car fires up instantly. But I cannot press on the accelerator without it stalling. It need to idle for quite a few minutes before I rev the engine, or drive it. This is happening at 50 degrees F, as I am in the PNW. Our temps do not really go much below 30.
I have had the FD and WUR rebuilt, and new injectors installed about 5,000 miles ago. New fuel pump, accumulator and filter at the same time. All the vacuum lines have been replaced.
The cold start valve and related sensor are working fine. Yesterday I checked the AAV, and it too is working, and getting 12v for the heater coil.
I believe the only thing left is to test the WUR. I have the gauge kit.
Is there anything else I should be checking?
79NINE28 (10-08-2021)
Team Owner
open or richen the mixture screw CW about 1/16 to 1/8 of a turn, small changes
Use as 3 MM allen thats about 12 inches long tool will work
1979 here...I feel your pain!
mine: very hard to cold start- many cranks but once warm fires right up.
Team Owner
79 your issue might be a clogged cold start injector,
add a bottle of techron and 6 oz of MMO to the fuel,
do lots of start stops so it has time to work
But it always firs right up, then stalls. So I was thinking the injector was working. But what else is there besides the WUR, AAV, CSI/thermotime and mixture?
Just a thought here. The vacuum advance on the distributor went south a while ago. I have not installed my new one yet.
How does advance affect cold running? Fuel is cold and condensing on the intake runners. Perhaps slow tomreach the combustion chamber. So ignition advance may be crucial?
I would also make sure your AAV is working correctly. If it's not opening when the engine is cold the car won't run. Remove it from the car, put it in the freezer then look through it to make sure it's open. The engine heat and the 12v from the electrical connector slowly close it as the car warms up. Since your car starts fine warm, I'm assuming it's closed, but may not be opening when cold.
