EZK ignition self tuning chip
(thread update, go to post 129 for the latest information on the chip tuning)
For a few months now, I have been running new version of a EZK ignition "self-tuning" chip from @PorKen.
With @PorKen 's permission, I am posting an update on my perceptions of the chip as he has made it commercially available (http://liftbars.com/)
The chip works by advancing/retarding spark of individual cylinders at each point in the RPM range for maximal performance and minimizing knocks. I’ll leave the technical explanation to Ken since its mostly over my head.
The ignition tuning improvements are subtle but noticeable. I dont have an dyno data, but can provide observations between stock and the the modified chip. Throttle response is better and the cars pulls stronger in the lower RPM ranges. Also it feels smoother in the rev ranges and even sounds a little quieter as well, which I don't understand. In the first few rounds of tests, my cam timing was set to Zero. The power gains seemed to be in the 3000-5000 rpm. I have since adjusted cam timing to 3-degrees advance and now the power gains seems to have shifted down into the 2300 range.
Also redline behavior was changed to give a soft cutout. Ignition timing is retarded just before redline.
The most interesting thing about the chip is you can really feel it adapting over time. I found the car would really ‘wake up “ after an hour or so of driving after disconnecting the battery / resetting the memory. I also had a test light set up to the diagnostic port and you can monitor the knock detection as well. Here are some test runs with the chip and test light
These videos were taken on my second round of tests.
You can hear and see some wheel spin between 2000-3000 rpm
This one I hit the rev limiter by accident.
All in all it’s a very nice chip, very drivable in all situations, and the throttle response is really fun for twisty roads requiring lots of accellerations out of corners. I like the constantly adapting timing concept.
Here is some information on my car: 1988 S4 5spd (stock cams) recent intake refresh with new knock, hall, CPS sensors and new 19-lb injectors (4-hole style). Exhaust modifications include: X-pipe, Cat delete, and 2.5” exhaust.
I am sure you have lots of questions for Ken, I am sure he will respond to this thread.
Oh my goodness, my car is so, so far away from being able to do what I just saw.
That sounded amazing.
Thanks for the review, I ordered one of Kens new S4 chips on this week and i'm doing xpipe install next week so will also report back on impressions in a 1988 auto in a few weeks. If i get more low end pull and responsiveness i'll be happy. You mention "adjusted cam timing to 3-degrees advance" can you say how you do that?
In my opinion every 928 DIY hack should have this kit in his tool chest- it is a very neat piece of kit.
The increments gained by small changes are barely if at all noticeable but revert to a full stock setup and then one can notice the sum of the parts when they are not there. Torque is what one "feels" when driving and unless your name is Lewis Hamilton changes [positive or negative] less than about 10 ft lbs are barely discernable for most of us or so I suspect.
You need to get hold of Ken's 32VR cam timing tool and the bumpstick [a custom wrench] then such changes are a doddle. Advancing the cam timing a few degrees gives the low end to mid range a bit more oomph at the expense of top end that will be slightly diminished - it is not for everyone but a quite understandable tweak.In my opinion every 928 DIY hack should have this kit in his tool chest- it is a very neat piece of kit.
Ken sent me the EZ Chip before the Badlands event. 2700’ish miles and the 89 performed flawlessly and pulled better than stock chip in every gear! Awesome and simple mod for the $$
Inventor
You can see in Mike's videos that the chip was fairly far along in learning. The knock light will flash less and less and eventually hardly at all as it records where each cylinder knocks. (It has to knock a few separate times in the same place to become permanent. The factory timed retard is still used so the knock is usually gone by the next revolution.)
Power and smoothness increase as the chip slowly ramps up the advance on each cylinder at rpms where it has not knocked before![typing](https://rennlist.com/forums/graemlins/yltype.gif)
Just need to get my hands on some factory GT and GTS EZK EPROMs to borrow for the stock maps - I do not trust the images I have gotten of the internets - will trade upgraded chips in return!
F451 (09-27-2020)
If I send you my GT or GTS chips, you would trade out original for new programmed chip just like you did on the early S3’s I got several years ago?
Inventor
checkmate1996 (11-19-2020)
Could you extend its "reach" so that it could adapt to non-factory cam profiles which may require "much sharper" ignition curves?
Sorry if this is asking too much about how you have programmed it!
F451 (09-27-2020)
I hope this isn't too obvious a question, but is the product that's been developed just the chip, with no need for a link to a laptop or other hard/software? Is there the capability to diagnose issues which the chip may not be able to compensate for?
I'm really interested in this product but it also seems a little like maybe I'm missing something. It sounds (not just the motor noise, above) like a fantastic solution.
Thanks for any clarification.
Cheers
Cheers
