Can I stack the stickers? Or must they be arrayed in a specific pattern?
Inquiring minds nd all...
I'm in for one of the chips at some point. Driving at 4000ft altitude most of the time, the engine can certainly stand more advance, but once in a while it treks down closer to sea level.
I (still) need to get the MAF rebuilt, and probably deserve an injector cleaning too since the car isn't driven often enough lately. Car is on tall stands in its hibernation storage spot now, with the passenger side pretty close to the wall of the garage. I left enough room there for access to pull the MAF, but not enough to open the door for EZK controller access.
A weak MAF probably works better up there in the highlands. I have driven the ever-so-twisty highway 242 over there (during the eye-blink it is open) when I had a WBO2 hooked up and it was oh-so-rich. The LH needs a altitude switch! (Using the coding plug inputs or the ROW CO pot input.)
Stickers may not be combined with any other label, insignia, hallmark, design, logo and/or decal. Stickers have no cash value. Stickers cannot be sold or otherwise bartered. Void where prohibited, taxed or otherwise restricted.
got out the chip installed into my 89 yesterday. First readings on the Assometer = wow. Throttle more responsive, pulls like a mule to redline, smoother idle. I had one of his old chips in my 87 and had forgotten what a difference it made. Could kick myself for waiting so long on this simple but significant mod. Thanks Ken...I’ve been Porkened! I need my sticker
JPS team colors for mine please. Black car with cashmere interior and all.
I'll get with you in the spring when the car drives again and the passes are snow-free. It's sort of drizzling snow here this morning. "Chains or traction tires" required. Looking for close to a foot of new snow on the mountain today.
I hope this isn't too obvious a question, but is the product that's been developed just the chip, with no need for a link to a laptop or other hard/software? Is there the capability to diagnose issues which the chip may not be able to compensate for? Cheers
This product is just the chip. No computer interface needed. You can install it yourself in under an hour.
Hello everyone. I thought I would post an update on mounting the diagnostic light into the pod for 87/88 cars as well as some updated videos of some of the features and adaptation test runs. In post #133 I walked you through how I made the diagnostic light using a standard pod bulb. I was able to plug the bulb into the "CAT" socket on my gauge pod. This is an unused socket (except for JP cars). I did have to mask off the traces on the foil to get the bulb to work. Apparently the traces are powered even though the CAT monitoring equipment are not present.
Here is a pic of the pod with the CAT light illuminated. I used an amber bulb to differentiate it from the warning indicators. Im pretty happy with the color and location. The amber is noticeable but not distracting.
The diagnostic light will illuminate in the accessory mode and will stay lit for about 2-seconds each time the car is started. One of the features @PorKen has added with the latest version of the chip, whenever the EZK adaption is reset, the light will stay illuminated until RPMs reach 1800
Now, if you are really bored for some 928 content here are some videos showing the adaptation process. I have loop circuit near my house (industrial area) where I can make 1st, 2nd gear redline runs on each leg of the oval. This first video captures the fist knocks as I am driving to the oval. There is a really good acceleration at 5:30 where I get full use of 1st and 2nd and fairly deep in 3rd.
Hope you find this as exciting as I do. Ken is still making some adjustments to the chip and will have indications for when adaptation is mostly complete.
