5A relay for HVAC head substitute ?
Since I was informed that the problem with my non working AC was a bad relay in the HVAC head I have tried to order the relay Dwayne suggested in his write-up "HVAC Compressor Relay Replacement Procedure". The Radio Shack relay 275-0218 is not available from any source I could find. There's a 12V / 10A DPDT relay (275-0043) available. but I don't know if it can be used. Anyone have any suggestions? Thanks
Chronic Tool Dropper
The one I used way-back-when looks suspiciously like this one: Search "NTE Electronics R14-11D10-12 Series R14 General Purpose DC Relay, DPDT Contact Arrangement, 10 Amp, 12 VDC" on amazon and you'll be golden. I used some double-stick tape to secure it to the rear face of the HVAC controller, so it is completely hidden. Put a 5A fuse at the freeze switch to protect the PC traces in the control head, a trick proposed by Greg Brown.
Different model but... any idea if this relay would work? Or is the R14 the better option? TIA
https://www.parts-express.com/NTE-R2...All%20Products
I used a POTTER & BRUNFIELD K10P-11D15-12 as recommended by Louie- I purchased 4 of them off Ebay in the States. I reckon they are the same as the Radio Shack item with a different logo on them.
Just as another option, Omron makes an equivalent relay as well, if they're more easily available where you are.
Omron MY2N-D2-DC12-S is nearly identical to the P-B relay mentioned earlier, though the pins are arranged differently, not having the coil terminals turned 90°.
P-B relay on Digikey: https://www.digikey.com/en/products/...1D15-12/254541
Omron relay on Digikey: https://www.digikey.com/en/products/...-DC12-S/369694
