928 Forum 1978-1995
Sponsored by: 928 Specialists
Thought I had seen it ALL !!!
Old Mar 15, 2004 | 12:19 PM
DR's Avatar
DR
Rennlist Sponsor
Default Thought I had seen it ALL !!!
I have seen everything from a 928 chassis being welding diagonally the full length of the car using an 83 on one side and an 89GT on the other side... to a beautiful 93 GTS being butchered.. BUT this takes the cake !!!
See if you can spot the "infraction" !!!
Always inspect your 928 suspensions carefully !!!
File Type: jpg
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old Mar 15, 2004 | 12:25 PM
GRGGOODSPEED's Avatar
GRGGOODSPEED
HOLY $I#t
Old Mar 15, 2004 | 12:30 PM
AO's Avatar
AO
Supercharged
I don't see anything suspect except for what appears to be a WELDED SUSPENSION ARM!. WOW!!!! Was it done with "allumiloy?" Ya know that stuff's supposed to be REEEEAAALL strong. Hope that's not your car... :eek
Old Mar 15, 2004 | 12:34 PM
tresamore's Avatar
tresamore
Photoshop Bully
Morons.
Old Mar 15, 2004 | 12:38 PM
heinrich's Avatar
heinrich
928 Collector
Hey be nice. It may be totally necessary to save the few dollars and in stead of using a good used part, put the occupants' lives at risk!! Now here's the real question .... how did they manage to get there in the first place?
Old Mar 15, 2004 | 12:39 PM
heinrich's Avatar
heinrich
928 Collector
OK I got it. This is one of thise clever mob hits ;-)
Old Mar 15, 2004 | 12:43 PM
BC's Avatar
BC
I guess those arms ARE hollow. And if there was enough force put on that end WITHOUT THE BUSHINGS MOVING, then it COULD break like that. What I mean is if that arms inner bushings seized, then they would not let the arm move up and down well.
Maybe they put some ghetto "outside the fender" whees on too.
Old Mar 15, 2004 | 12:49 PM
DR's Avatar
DR
Rennlist Sponsor
NO, it is a current restoration project I am starting on. If you get the chance, go to the restoration page on my website and look at the photos on the bottom of that page....scary !!!
Direct link - http://www.928gt.com/restore.htm
Old Mar 15, 2004 | 12:54 PM
John..'s Avatar
John..
Never know, depends on how it was done. I've seen some clever welding over the years. When I worked at a BWM shop here in town, there was a 635 that had the whole front end clipped on, it had literally been cut in half and welded together. That did not qualify as clever welding.
I would have replaced that arm, would seem like it would have been less $ in the long run...
Old Mar 15, 2004 | 01:01 PM
atb's Avatar
atb
I guess that's one way to get a little extra camber.
DR's Avatar
DR
Rennlist Sponsor
True, but in this case something was not done right. Check out this photo and notice that the lower spring plate is catching on the upper control arm and bending the spring plate....
File Type: jpg
Old Mar 15, 2004 | 01:08 PM
John..'s Avatar
John..
Oops!
Old Mar 15, 2004 | 01:29 PM
karl ruiter's Avatar
karl ruiter
The only hope is that somebody didn't have a clue about the availability of used parts, went to the dealer, was quoted more than the value of the car for a new arm, and decided to take their best shot.
Old Mar 15, 2004 | 01:30 PM
Garth S's Avatar
Garth S
All that, and the aluminum ball joint carrier seems to be intact?
The bent spring plate may well have happened when the control arm seperated - it would be tough to jig and weld that far out of spec, but the impossible is often reality.
Anyway, a good eye for another entry to "The Chamber of 928 Horrors".
Old Mar 15, 2004 | 01:46 PM
bcdavis's Avatar
bcdavis
With that title, I thought it was going to be the "spider man" car again...
