It would be nice if the lights were encased in a plastic or fiberglass mount, so that they would be recessed in two holes, with no empty space around them. THEN put the clear plastic cover over it...
Making it look more like the newer PES headlights.
Example:
But nothing but big cheers for your efforts to make things, and actually experiment!
They're rock solid, fully triangulated, mount to factory holes, and position the lights just perfectly with no apparent beam cutoff. (Hard to tell if things are going to be level when you're tack-welding the bits together for the first time!)
I've figured out the wiring. It turn out to be (unexpectedly) simple, I just need to buy a couple of relays and fuse holders. I am going to wire directly to the 'jump-start bolt', for clean power to the 65W H9 bulbs and I've decided to keep the low beam on when the high beams are switched on, for more light output.
I still have to make the cover. It looks like I can use just a simple flat sheet underneath to hide the inside of the fender.
Very, very cool. If you built a fiberglass housing you might be able to move the lights out a bit. Then the acrylic cover could still sit flush on the fender lines and the housing could sit in the lip of the fender where the lights currently sit. I have been dreaming about this happening for years without having to modify the fenders ala Jaquamond or Strosek
Keep it up, I for one and very excited about your progress.
I positioned the lights so that both the low and high beam would clear the opening, and be as high as possible. I also wanted to keep the cover simple (so I could make it) so having the lights recessed helped here too.
The light centerlines are ~25" above the ground (DOT legal is 22"-54"). The lenses are 2-3mm inset from the fender opening. The low beam appears to be cut off, but the active part is the fresnel lens in the center which is completely exposed.
If you look in the first pic of this thread, the lights are lower and extend ~15mm into the fender hole.
Jim_H - I'm quite proud of the brackets:
The girlfriend (normally unmoved by anything I do with my car) said: "Your car looks mean... it looks like a boy now - it looked like a girl before".
Very, very nice job. They'll look like they were put there by the factory with some sort of backround fill and covers as has been suggested.
Especially smart that you used the stock mounting points.
Yup, all that headlight stuff is quite heavy isn't it? Especially that cross-bar. You'd think they would've spent a few $ and made it lighter than that.
Well, sure... reflector size can be more important than wattage.... and I like the 8" setup, 20 lbs extra weight and all. I just love this kind of stuff, experimenting around, checking out the results.... Go PorKen! I may not be interested in implementing all of your ideas but bravo for sharing! Great stuff!
