928 Forum 1978-1995
Sponsored by: 928 Specialists
Fixed Headlights Installed
Old Feb 23, 2004 | 03:46 AM
GoRideSno's Avatar
GoRideSno
Porken,
I like it! This my favorite project so far. Keep up the good work.
Andy K
Old Feb 23, 2004 | 08:27 AM
Zandramus's Avatar
Zandramus
I dont know, I think the stock lights make the car, they are very unique. The lights you have made look nice but they are similar to everything else out there. IMHO the stock lights are better.
Z
Old Feb 23, 2004 | 10:32 AM
ruf965's Avatar
ruf965
Porken,
The brackets are ingenius. Excellent work. Please keep us posted. I wonder if the factory ever contemplated something like this?
Stephen
Old Feb 23, 2004 | 12:40 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Something like this for the final would be nice:
Old Feb 23, 2004 | 01:00 PM
BC's Avatar
BC
Porken - Can you weight each piece of the original assembly and tell us what the heaviest piece was? I think that the weight savings is more important to me then the look change. So if your saying that middle bar is heavy, then we can get a different version of it. My bumper is off, so I would like to try soime changes in that area. Were you planning on doing some sort of pic with the light beam pattern, or objectively going out in a different car and seeing what the light looks like to oncomming passengers?
Old Feb 23, 2004 | 02:54 PM
PorKen's Avatar
PorKen
Inventor
Sharkskin, BrendanCampion,
I'll post pics of the beams as soon as I have the lights working! The lights are DOT legal and are said to have really nice optics/beams. The direct wiring should enhance the light output too.
VU,
Weight, aerodynamics, 'flash to pass', 'instant on', more focused/useable light output, 'modern look'.
I like the looks of the pop-ups too, but truthfully, I like the look with the headlights down more. I'm hoping this will end up with a stock look, headlights down.
My headlights would often not stay down (keep cycling) when turned off, and it was easier to make these than fix the old.
BrendanCampion,
By order of heft: motor, crossbar, base, light. If the crossbar and base tubing was replaced with aluminum (titanium ), that would take most of the weight out.
Hacker-Pschorr,
I'm hoping a fiberglass guy will step up and make a bucket/cover to go with my bracket.
The lights could be moved forward if one of the four mounting ears (three are used) were trimmed off and a cover with bumps like the second pic was installed.
I didn't want to modify the lights in case they sucked and I had to sell them on eBay!
Here's what I expect it will look with just the acrylic cover that I plan on installing:
This is photoshopped.
Old Feb 23, 2004 | 04:30 PM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
Cool PorKen......Remember the drivers side fender well has the vent tube for the alternator in it. You prolly want to get the covers on before you drive on any dusty roads, or put a filter head over the end of the hose up in the fender well.
You are a creative bugger, I will give you that..............
Old Feb 23, 2004 | 04:54 PM
saxapeeel's Avatar
saxapeeel
"what on earth have you done?
i feel betrayed."
- your 928
i am sorry but i like the stock lights a lot better.
chris
Old Feb 23, 2004 | 04:56 PM
Red UFO's Avatar
Red UFO
Sorry but I don't like them.
Perhaps if the fender had custome places it would look better. But my hats off you for playing around with the shark and making up new ideas
Old Feb 23, 2004 | 05:04 PM
saxapeeel's Avatar
saxapeeel
i just hope you saved all the other parts and did not ruin them taking 'em out. you may change your mind and want to put them back in... hint, hint.
chris
Old Feb 23, 2004 | 05:18 PM
Red UFO's Avatar
Red UFO
//psst.. Porken pass the doobie this way!!!
Old Feb 23, 2004 | 08:27 PM
bcdavis's Avatar
bcdavis
I really like the Jacquemond dual projectors, with recessed lights.
I just think it needs to be slick, not hacked.
But the first step is getting them in there.
If you want, check out this guy's site:
http://www.fototime.com/ftweb/bin/ft...AD13CAF9177541
He built an awesome V8 Z car, with some really nice homemade fiberglass work.
Including recessed projection headlights...
Old Feb 23, 2004 | 08:41 PM
PorKen's Avatar
PorKen
Inventor
Gretch - I have the replacement Bosch alternator; no hose.
Dozman - thanks!
saxapeel, RedUFO,
You guys are so... 80's. Pull the LaCrosse polo T's from over your eyes and take an objective look.
Old Feb 23, 2004 | 08:57 PM
ErnestSw's Avatar
ErnestSw
The recessed cowl effect in the bottom picture of Hacker Pschorr's post would look nice. It would clean up the profile of the fenders. You'd need covers unless you wanted to start a bug collection.
It would be a bear to get the compound curves right.
Old Feb 23, 2004 | 11:18 PM
Beth's Avatar
Beth
Excellent job - but I like the stock light's better. The "froggy" lights are so unique to the 928
