928 Forum 1978-1995
Sponsored by: 928 Specialists
Upgrading to ROW 4.7S engine
Old Jun 22, 2019 | 08:43 AM
kiwiokie's Avatar
kiwiokie
Default Upgrading to ROW 4.7S engine
I am looking at replacing the stock 4.5l engine in my ‘79 Euro with a twin distributor ROW ‘85S engine.
I am trying to get a list of what would need to be changed out for this conversion and here is what I have so far:
Engine cross member and mounts
Engine wiring loom
Engine bay wiring loom and 14-pin connector
Central electrical panel
Fuel pump
Coil
Exhaust system
Anything I am missing?
Would appreciate hearing from anyone that has done this upgrade.
Thanks in advance, John
Old Jun 22, 2019 | 12:19 PM
skpyle's Avatar
skpyle
LH and EZF modules
Fuel injector harness
Ignition amplifiers and harness
Ignition coils and coil mounting hardware
Old Jun 22, 2019 | 09:41 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
MAF and a new set of 84 Euro distributor wires
Old Jun 23, 2019 | 01:23 AM
soontobered84's Avatar
soontobered84
John,
Why wouldn't you just upgrade to an 80-'83 4.7L Euro engine and run the same CIS injection. You'd have only 10 less HP and a lot less headaches to your changeover.
Old Jun 23, 2019 | 01:26 AM
The Forgotten On's Avatar
The Forgotten On
Just use the engine sans the ignition system and fuel injection system and swap your stuff over.
It will drop right in at that point. You also don't need to change to the later mounts. The block has the holes to use the solid mounts and shocks.
Old Jun 23, 2019 | 10:00 AM
kiwiokie's Avatar
kiwiokie
Originally Posted by soontobered84
John,
Lose 10hp!!!! How can you even suggest such a thing!
The ‘85S engine is local to me and is complete so logistically it makes sense. Just trying to work out all the bits I need to buy along with the engine and brains. The CIS hybrid concept is interesting but the throttle body and intake runners on my car are a smaller diameter than on the S models so would lose some HP there also. Also not confident in my ability to troubleshoot rough running problems with CIS if I mix and match so will likely take the “all or nothing” approach.
Old Jun 24, 2019 | 09:49 AM
Petza914's Avatar
Petza914
Look into the cam profiles of your 4.5L vs the 4.7L you're moving toward. Using the cams from the 4.5L might give you higher performance. That's what I did when installing an '83 4.7L (non-Euro) into my' 79 non-Euro. In my case, the 4.5L cams have higher lift and duration so I've ended up with a tiny displacement bump, higher compression ratio, and better cams. My car has a 928MS Powerdyne Stage 2 supercharger on it too.
Old Jun 24, 2019 | 12:35 PM
soontobered84
Petza, your situation was different.
Kiwiokie has a 4.7L Euro engine that already has great cams, so there will be no need for him to change cams.
Old Jun 24, 2019 | 12:41 PM
Petza914's Avatar
Petza914
That's not what his initial post says - it says he has a 4.5L '79 Euro and is looking to install a 4.7L ROW motor into it, unless I'm reading it wrong. You recommended he go with a later 4.7L Euro motor instead, but I don't think that's one of his current considerations or something he already has.
Old Jun 24, 2019 | 02:55 PM
soontobered84
That is true, but in post #6, he says that the 85 engine is local to him. In effect, he already has an 85 Euro(ROW) engine located, which makes my post moot.
His original 4.5 cams would have definitely been better than the cams from a US 84 engine, but I was suggesting that he use an earlier (80-83) ROW Euro 300HP engine which uses CIS injection just like his original engine and would make the swap far less complicated.
Old Jun 24, 2019 | 05:45 PM
IcemanG17's Avatar
IcemanG17
I agree a CIS Euro would be an "easier" conversion but you will gain performance with the Euro S LH setup once complete. Another idea is to make a 5L hybrid euro out of an 85-86 USA short block. There is no replacement for displacement!
Old Jun 25, 2019 | 12:05 AM
kiwiokie's Avatar
kiwiokie
Yes I currently have a ROW (Euro) 4.5l CIS engine and have the opportunity to purchase a ROW (Euro) 4.7l LH injection engine. I have CIS on my 911SC and it works great but have read many horror stories of people rebuilding their CIS systems with new and rebuilt components and struggling to get it to run right. This pushes me towards LH even though it seems it will be a lot more work.
By Verdad Gallardo | 2026-04-28 19:00:17
