View Poll Results: For only a head gasket replacement only on a 16v and no other service work, would you
Voters: 59. You may not vote on this poll
Blown/Damaged Head Gasket?
#46
If you score Euro heads, then also find some Euro cams too.
They are more supercharger-friendly in that they'll lower the dynamic compression ratio of the engine, thus, help minimize detonation.
Classic failure mode of a supercharged engine is a blown head gasket, and usually caused by detonation.
#47
83/84 US cars were 9.3:1
84-86 Euros were the highest at 10.4:1
85-86 US cars were at 10.1:1
then everything after that, except the GTS was 10.0:1 with the GTS being slightly higher at 10.4:1
If I end up putting heads onto my block, I'm going to install them with upgraded gaskets from 928MS. If I end up installing the 4.7 rebuilt motor, I'm going to leave things assembled as they are and drop it in. That motor would have a compression ration of 9.3:1 which should be OK. Probably going to install new fuel injectors just to be save if I go that route, unless I also change over to the L-Jet fueling system that's available with that motor.
Any opinion on K-Jet vs L-Jet for supercharged setups - avoiding a computer and tuning manually with mixture seems easier.
#49
I had head gaskets blow on the exhaust valve side in my blower motors in the Pantera. It stopped when we O ringed the heads. I'd do a compression test on each cylinder. They don't always pop where you get water in the oil. I've seen them let go and the exhaust gasses push all the coolant out thru the cooling system. BTW, I got my radiator cap from Roger, and I believe it's a 13 pound cap. Also Greg Brown says the head gaskets on these cars are failing due to age related problems. My 89 is supercharged, and I'll be changing head gaskets as a precaution when I do the top end refresh.
Call me when you do that. I'd be happy to come out and help you pull the motor and do the heads. It's easier with extra sets of hands.
#50
He says the K-Jet is a better fueling platform for supercharging providing it's in good shape (which mine is), so I'll be staying with what I have on that, but probably installing with new injectors and seals just to be safe, and some braided stainless fuel lines I've found.
#52
I bought the recently rebuilt 4.7L M28/19 motor today from user BC for very reasonable money - thanks BC! It was previously in ladybug's car.
So that's the plan...pull the motor and replace it with this 4.7 and then reinstall my K-Jet setup and supercharger onto it. Also going to install new injectors and Greg Brown fuel lines.
The motor will be starting the trip my way from San Diego sometime next week and I'll start doing prep work on my car in the meantime as I've now made a decent list of stuff I am going to do.
Hoping I can get it all put together in time for SITM.
If there's a good 16v Engine Pulling for Dummies (Rookies) writeup with step by step instructions someone could point me to, that would be awesome.
I'll pull the heads from my current motor after I get everything else done and decide what to do with it.
#53
Vegas, Baby!
We'll tool around in the Pantera this time too. Gotta start driving it.
#54
#55
All easy stuff, especially on a CIS car.
Remove hood
Unhook exhaust
Pull fan and radiator
Unhook 14 pin electrical connector
Disconnect 2x fuel lines and throttle cable.
Disconnect driveline at clutch
Drop the clutch? (don't totally remember if I pull the clutch down or not. Probably makes the pull easier if you do as otherwise it has to come pretty far forward)
Bell housing bolts and motor mounts.
Pull baby pull.
WSM has a good write up, I think.
Remove hood
Unhook exhaust
Pull baby pull.
#57
Remove hood
Unhook exhaust
Pull baby pull.
Remove hood
Unhook exhaust
Pull baby pull.
Does the hood really need to come off, or can you just disconnect the struts and make it more vertical or pad it lay it back toward the windshield.
I'm planning to put it on the lift so I can access things from above and below as need be, then roll it off the lift so I can get a cherry picker with leveler under it to lift the motor out.
#58
Hi Pete,
The hood comes off easily and one person can do it. I popped the struts, then laid blankets across the engine and fenders. Then I lowered the hood until almost closed, but I could still access the hinge bolts. Pull the bolts and walk around to the front of the car and lift the aluminum hood. Very easy, and the access is vast.
Good luck,
Dave
Good luck,
Dave
#59
Mark the position of the hood hinges with a sharpee. If you have fender service guards this would be a good time to use them as it is easy to bump the hood against a fender as you are lifting it, if you are doing it by your self.
#60
Disconnect the engine at the torque-tube and bellhousing. Pull the engine with bellhousing attached.
Less is more at this stage.
