928 Forum 1978-1995
Sponsored by: 928 Specialists
01117 / Restoration / Phase II / Engine & front Suspension
Old 03-30-2019, 11:32 PM
  #106
mit Wasser
mit Wasser's Avatar
Re: ''I’m not sure they left the factory this pretty''
Possibly they were -moments before Heinrich on the production line started smathering it on heavy with the cosmoline gun......
Old 03-31-2019, 03:59 AM
  #107
Ad0911
Ad0911's Avatar
Originally Posted by mit Wasser
Front suspension finished earlier this week. Brakes for that last moment before they are filthy. Plating is Gold Cad. Karp's Brake Service in Upland Calif. knows how to properly restore calipers.
I am jealous about the gold cad on the calipers. This process is no longer allowed in the Netherlands. The yellow zinc proces doesn't stick to the caliper material. I had this tried out but no result.
Old 03-31-2019, 07:11 PM
  #108
NoVector
NoVector's Avatar
Did the OBs have red paint on one of the lugs?
Old 04-01-2019, 12:12 PM
  #109
mit Wasser
mit Wasser's Avatar
Default Goin’ N.O.S.
I’ve been reading a lot of Import Tuner magazines. Last week I stopped by a local tuner shop to see how these guys are getting such massive H.P. numbers from some really small motors. After seeing their dyno results, I took the plunge and installed a full Stage II system on 928801117 that is current under restoration. According to the master tuner at www.evasivemotorsports.com/ he calculated that my 4.5 liter will be pumpin’ out about 480 H.P., just with Stage II! The master tuner at Evasive has 2,200 dyno hours so I know his calc’s are the real deal!
It took some time at my machinist - but we made a fixture to set the precise angle on each of the intake runners for drilling and taping for the optimum nozzle angle. See below pick. So bitchin’. With the fixture the other 7 intake runners went really quick. PM me if you want to do your runners as the fixture is still set up in the mill.
I can already hear those rear tires squealing in third!
Watch for future posts on Stage III and IV –targeting 560 RWHP! This was so easy!
Old 04-01-2019, 12:20 PM
  #110
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,831 Likes on 1,380 Posts
Whiskey Tango, Paul, I step away from the project for a while and you pull _this_? How the hell are the judges going to react to that?
Old 04-01-2019, 12:26 PM
  #111
mit Wasser
mit Wasser's Avatar
Rob,
Sorry I didn't mention this. It all moved very quickly last week. If I show the car I guess I could remove it? It would have been great if you were there -as I did screw up one of the holes drilled in the trunk floor for the N.O.S. bottles. I am smelling a lot of raw fuel vapor. How close is the top of that fuel tank to the floor?
Mit Wasser
Old 04-01-2019, 12:52 PM
  #112
William A
William A's Avatar
uh, is this Subie version of "Invasion of the Body Snatchers"? Mit Wasser exposed as a Manchurian restorer!
Old 04-01-2019, 12:54 PM
  #113
linderpat
linderpat's Avatar
Received 2,433 Likes on 1,318 Posts
ahem; see my back seat thread and Ross's carburater thread
Old 04-01-2019, 01:51 PM
  #114
William A
William A's Avatar
Like your "back seat" thread (well done, Ed!) I enjoy the banter and replies they invite. Mit Wasser should change his name to "Mit Comodie", he is a seasoned prankster. See more of his April 1 handiwork here:
View this post on Instagram
Old 04-01-2019, 02:38 PM
  #115
mit Wasser
mit Wasser's Avatar
Default new graphic for the rear bumper
Re: Subie Version / Body snatchers.
William A. - clearly you totally get the idea on this ''new build''. Here is the new graphic for the rear bumper........
Old 04-04-2019, 02:25 AM
  #116
mit Wasser
mit Wasser's Avatar
Default Torque Verification's / documentation
Image one is a formatted version of @Rob Edward's spreadsheet noting every significant bolt on a 928. Rob has listed the location, bolt size and the area specific torque value. This has been extremely helpful is fighting sometimers disease (aka CRS), when you have tightened the bolt but can't remember 10 minutes later if you did. I worked in one specific area at a time doing the torquing. and paint dotted as soon as the bolt / nut was torqued. The Foamcore board makes it easy to transport around the chassis. The zoom in section in image two is the secondary red dot corresponding when each bolt is complete. The board will remain with the vehicle's documentation. Thank you Rob Edwards.
Old 04-08-2019, 01:35 AM
  #117
mit Wasser
mit Wasser's Avatar
Default up and running
The past week has been focused on the fuel pressure, vacuum leaks, vacuum line routings and a modest amount of trouble shooting. The result is a very smooth running engine. Rob came over today and we set the timing, then rest the idle speed. So far no leaks. Took it for 5-6 short test drives on Saturday. Sunday was 25 miler up to the BMW restoration shop. The transmission is sublime. Silky smooth, nice synchro engagement and the mild chirping of the LSD at low speed. Its awesome to have it back on the road. Some minor wire dressing and label remain.
Old 04-08-2019, 12:45 PM
  #118
linderpat
linderpat's Avatar
outstanding Mit! What a build.
Old 04-08-2019, 01:47 PM
  #119
Rob Edwards
Archive Gatekeeper
I stopped by Paul's for a test drive yesterday, and was struck by Paul's garage floor. Usually when I finish a project the EPA has to come in and direct a Hazmat team to perform the cleanup. In Paul's case, not a frickin' drop of juice on the floor. Inconceivable.
Old 04-08-2019, 01:54 PM
  #120
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
nice job hiding that NOS
Quick Reply: 01117 / Restoration / Phase II / Engine & front Suspension
