928 Forum 1978-1995
Sponsored by: 928 Specialists
Ben's 1982 928 S "restoration"
Old 11-03-2023, 06:09 PM
  #241
Ben006
Ben006's Avatar
Okay I'm 1/2 year late ^^
Cage is taking shape
Cage is done and I drove it. Found some problems, like have no power steering...
It does shoot flames
Old 11-03-2023, 06:19 PM
  #242
Ben006
Ben006's Avatar
Then I broke my pinky...
OOps
Received the foot rest !
And wrapped the exhaust (one handed ^^)
Then received some more stuff !
Can't wait !
My finger kinda healed... crooked, and 1/4 inch shorter...
Door card are installed
Mounted the PS line solidly
The pump I chose is kinda old... I have to bleed it first.
Exhaust wrap is done, no more cooking my butt !
Taking shape !
The following 2 users liked this post by Ben006:
Graham Bates (11-04-2023), PK68 (11-04-2023)
Old 11-04-2023, 08:01 AM
  #243
Ben006
Ben006's Avatar
I decided to switch to a PDM, the same brand as my ecu !
Keypad goes there
Took the old harness out
An new one in
both ecu will be placed here
I also removed the engine harness to simplify it a bit.
Then I tackled the roof mould.
PK68 (11-04-2023)
Old 11-04-2023, 09:13 AM
  #244
Ben006
Ben006's Avatar
Electronics are working well !
Gotta clean up now
Idid my first hillclimb !
What better way to do your first race alongside Raymond Boutinaud ?
Despite being in the middle of July it was awesome !
The car is a bit big and heavy for this kind of exercise,
Result ? 8th in production and 1st in class !
Ok, if you include single seaters I'm 24th ^^ But they're cheating !
I did buy that
Old 11-04-2023, 09:31 AM
  #245
Ben006
Ben006's Avatar
Got a FIA seat
A FIA solid state circuit breaker
And an automatic fire extinguisher
Forming the extinguisher lines
new seat
Circuit Breaker
Roof being vacuumed
I thought my cam tower were leaking so I replaced the gaskets AGAIN...
And some stuck lifters
I did a photoshop of what the car will look like when done
WestInc (11-04-2023)
Old 11-04-2023, 09:38 AM
  #246
Ben006
Ben006's Avatar
It's got a roof !
Need to trim it.
I found the leak... it was the camshafts seals...
Trimmed the roof panel.
Installed the outside buttons for the fire extinguisher and circuit breaker.
I started the plug for the headlights covers.
Old 11-04-2023, 09:42 AM
  #247
Ben006
Ben006's Avatar
Pour la 928 :
I glued them
new harness
Then I machined a part for the hatch. A 680gr of aluminum
machined
Final weight 31gr !
Old 11-04-2023, 09:49 AM
  #248
Ben006
Ben006's Avatar
I molded the headlights
Polyester resin released a LOT of heat ^^
Mais bon, le moule à quand même fonctionné même si les gaz dégagés par le polystyrène ont créé des bulles...
Butg I fixed it
First try:
Il y avait pas assez de mou sur le film à vide, et j'avais des fuites... en plus de ça la résine a mis plus de 4H a polymériser... donc le rendu est moyen...
Il faut que j'améliore mes techniques de bagging !
Out of the mold:
The gel coat I used is crap...
So I didn't use any on the second try !
J'ai eu des petits problèmes d'adhérence sur les flancs verticaux, mais c'est surtout que j'ai pas encore une assez bonne technique !
Well better !
Though I want to redo the whole process to make a better mold, and better parts, less tall.
I put the plexi windows in
I wanted to keep the aluminium window trims to keep a stock look.
tv (11-11-2023)
Old 11-04-2023, 09:57 AM
  #249
Ben006
Ben006's Avatar
So... I was visiting my old job... and they asked me to come back, gave me a raise, and flexible hours... So guess what ? I'm a Porsche Tech again ^^
And the 928's got eyes again !
I received the prototype for the roll center and geometry correction for the front of the 928 !
Door locks bits !
And stalks ! All black anodized cnc aluminum !
Love them !
Carbon roof is at the body shop for it's last clear coat ! Can't wait to have it back and glue it on ! It looks so great !
I took some time to clean the windshield... I never did it, it had a ton of overspray !
I go back to the shop tomorrow, if it doesn't rain I'll drive and tune the car a bit.
December 2nd I gotta have my trailer done so I can bring the 928 to the track !
Not to race, but to show it off and tune in on an empty road.
Old 11-04-2023, 05:15 PM
  #250
grepin
grepin's Avatar
All I can say is incredible. Very motivating.
The rear hatch latch is intriguing. I will have a look back through the thread to see how it works. Mine is a constant battle since its all falling apart. I often thought if I could just add a push button type variant then I would be happy. Might be a small market there.
Old 11-05-2023, 01:53 PM
  #251
Ben006
Ben006's Avatar
For the latch, it's a "quick latch", so there is no locking, in latches and unlatches when you press on it. It's fairly secure, but not really for street parking :/
Today I worked at the shop. We cleaned my friend's engine, and I took the opportunity to drive the 928... eheheh I already love it !
I do need to move the pedals back by a good 3 inches though !
The power steerings works perfectly... works way better when you actually fill it up the proper amount of fluid ^^
The engine still needs some tuning but it works already eheh. It drifts well, very easy to throw around !
Quite pleased with the sound !
We did work !
Old 02-04-2024, 06:27 AM
  #252
Ben006
Ben006's Avatar
OK so a LOOOT happened in the last months...
In October I got asked to work back at the Porsche Center, for three months, I agreed.
At the end of the contract they asked me to come back full time.
In the same time I got offered a job in mechanical design at another company, got to the end of most of my projects, and found a new shop !
So, I accepted the job at Porsche, the other job was super nice, but it would have been hard to continue both BAD and a new job.
I got the new shop, a lot bigger, more expensive but still fair.
I had a week to move my stuff ( I still have the old shop for another month), I did, and I love it ! There is so much room !
I'll get some go jacks to move it easier.
The old shop had 4 lights. This one has 22. No dust, better insulation, easier to go in and out... perfect !
To be able to work from anywhere I got a laptop instead of my worstation. Then immediately upgraded it with 32Gb of RAM and 2Tb of memory. Should be plenty, enough for a few years !
Monday I start back at Porsche, I hope they had time to install my lift
PK68 (02-04-2024)
Old 02-04-2024, 03:43 PM
  #253
NvsCardealer
NvsCardealer's Avatar
For most people and EFI conversion is a can of worms that never gets finished. A huge percentage of such projects that are documented here start out bravely and then stall. So keep the CIS as fall back.
Old 02-04-2024, 05:13 PM
  #254
Darklands
Darklands's Avatar
Received 1,186 Likes on 640 Posts
Much success in your new shop!
Old 02-04-2024, 05:14 PM
  #255
Graham Bates
Graham Bates's Avatar
I converted my '82 928s a couple of years ago to full EFI using a Microsquirt. Cheap and easy and way better than mechanical injection. I sold my CIS on and it paid for about 50% of the conversion. The 928 with a modern EFI is a lovely car!
Quick Reply: Ben's 1982 928 S "restoration"
