928 S3 Rebuild
Anders
Last edited by Anders Flodin; Sep 1, 2018 at 05:53 PM. Reason: picture did not show
Can anybody tell me where the hoses/pipes from the vacuum thermostatic switch are routed?
So I got to work on the 928 a bit more. Nothing major but on my way to pulling the engine. Dropped the exhaust and also removed some more odds and ends. Managed to finally drain the oil and found this:
Mmmm! Looks great! I looked inside the oil baffle and water bridge/ports. It actually looks mint inside. Looks and measurements are two different things though. Once I get the wheels back from powdercoat I can get tires and then drop this thing down and pull the motor. Dreading putting head gaskets on it and doing the head work but will see how it goes.
There are larger pieces on the magnet that I'm not used to seeing on anything that I own. Don't know what this would be.
Electrical: I got the electrical harness off the front of the motor. New harness from Sean on the way : )
Motor: Minor things such as a/c compressor off and hung up
I could use some advice on pulling the trans back. Still hung up on whether I am pulling the trans back while car is on the ground? Just roll the wheels back?
Also I have read about the motor mount bolts and length being appropriate so as to not bust the block. I know it is engine stand dependent. I plan on using threaded rod. What I dont know is how far into the block the threaded rod goes?
WSM says clutch must be removed for 87 and up. I'm assuming my 85' I just pull the trans back to clear the shaft and I'm good to pull the engine forward and lift out. Not sure the WSM really has all the steps I'm looking for and I'm a bit lost.
Wheels are back from powdercoater with new tires Michelin Pilot Sport AS3 225/50/16. I'm sure to get larger wheels and tires at a later date but right now they look really good and appropriate for the stage of the project I'm in.
Brakes: Brakes calipers and mounting brackets are now off, I need to get the pistons out and then they are off to the powdercoater, then rebuilt with new kit from Roger
Hopefully I can get the engine out next weekend. Thanks all for the help.
So I am removing clutch, removing Bellhousing bolts, lowering car onto it's wheels? and then removing 2 trans bolts and pulling it back a couple inches? then i'm free to pull the engine?
Second question is I removed the clutch, went pretty well after researching it for 2 days straight and making sure I understood what i was doing. my issue now is that the flywheel lock tool could not engage the flywheel, it doesn't even come close to peeking out the hole of the slave cylinder. I am now thinking i either have the tool for early cars, or i need to put the clutch back in and engage the starter teeth. would be great to know ahead of time before i attempt to put the clutch back in only to find out i was wrong on this last point.
i lied. i have a 3rd question. the wsm says to undo the ce electricals and push the rubber boot through, but doesnt say to send the connectors through as well. i am assuming this is the obvious thing to do.
Thanks! I'm close. Very close to getting this engine out.
I happen to have a new front moon roof seal if you need it, got 2 from the supplier...
from what I have read you have to support the torque tube so it does not hang in the transmission, big torque from gravity on the tranny and spline connection
Do support the bellhousing/TT with a tie strap from underneath. Take out the two bellhousing bolts on the bottom, then car on ground, remove the two top bellhousing bolts with the air cleaner removed, and engine supported by the cherry picker. One can use a lot of extensions and remove the top bellhousing bolts from underside, but the engine has to be supported and then the car dropped down to pull out.
Yes, remove the two large connectors from the LH and EZK modules on the pax footwell side wall. Remove the boot on the lower right firewall behind and above the CE panel. Stuff the connectors through the firewall one at a time, and attach to the eng with a zip tie, or bungee cord.
Sounds like your flywheel lock is the wrong one. Don't mess with the flywheel until the engine is out and on the stand. It comes out with the engine.
I did get the LH and EZK and assortment of wires out the firewall. That was really the final hurdle.
The reason i need to lock the flywheel is to loosen the crank bolt. I have the late flywheel lock tool which should be correct for my 85. The issue is that the clutch is out and when i put the lock tool into the slave cylinder, there is no way it would ever come in contact with the flywheel teeth. Looking directly through the slave cylinder hole there are no teeth visible on the flywheel, the diameter is just not there. Now if the starter ring gear attached to the intermediate plate was still there than i bet it would engage but I would like to make sure that is the correct step before I put the clutch back in only to find out I was wrong.
edit: If you are trying to pull engine with the radiator in, just - don't. It takes 2 allen screws to pull the rad. You'll have room to pull engine with the pullys in place if you like.
YMMV, objects in mirror, contents have settled, and may cause **** leakage.
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
