FS: Bare blocks w/matching balance shafts + covers, and good condition cranks
Hey guys, I have four 2.5 liter blocks with matching shafts/covers/crank girdles taking up space in my garage. They will all need overboring or sleeving to be used.
I also have four cranks in good condition, ready to run.
$85 ea for the blocks and $85 ea for the cranks
Located in South Austin, Tx but willing to ship at buyers expense.
Edit: Also have a bunch of other engine components for sale. Two oil pans, one early and one late. Also have 3 sets of NA rods and pistons, an NA head, and a loaded cam tower with lifters for sale.
The bare blocks with shafts and girdle weigh a hair over 70 lbs and as long as the box is under 150#, it can be shipped pretty inexpensively. my guess would be around $80 dollars but I can certainly get a more accurate quote for you.
Rainman
The one I referenced was probably 3-4 years ago, and the crank was in the same box as the block that time, no separate crate like yours was...and the crate was smaller than the box/tub your block came in because it didn't have a timing belt tensioner stud to clear (87+ block).
Just a note to everyone; as stated above either a block or a crank is relatively inexpensive to ship, but a block + crank together is probably over the weight limit and would likely have to go freight, so bare that in mind.
