3D Printing 924 & 944 Parts - Development and Discussion
Old 04-15-2016, 09:46 AM
  #121
odonnell
odonnell's Avatar
Originally Posted by J1NX3D
i noticed the drain plug in my shower...
LOL I'm glad I'm not the only one who calls it that.
I painted mine with silver engine enamel I had sitting around
Old 04-24-2016, 06:35 PM
  #122
KVDR
KVDR's Avatar
It's been quiet in here! My excuse is that I put my car back together and have been enjoying it as much as possible lately.
On the 3D printing front:
New bellhousing plug colors added - Green and orange
Same five colors are available for ISV and Turbo Aux Waterpump clamps.
I previously shared the 3D Printer Files (STL) in this thread so anyone with a printer can make their own. If you don't have access - I put a few up on eBay.
Old 04-24-2016, 11:19 PM
  #123
snb13
snb13's Avatar
2 more parts come to mind:
The air box/timing cover hose delete caps.
And, similar to your turbo aux wp clamp band, something to go inside the clamp for the upper radiator hose (it attaches to the air box bracket.) All the ones I've seen are wrapped with electrical tape--including mine
Old 04-25-2016, 10:06 AM
  #124
phL
phL's Avatar
would you mind sharing the stl files?
car4philip at gmail.com
thanks a lot!
Old 05-30-2016, 09:13 AM
  #125
newkie
newkie's Avatar
Ah, a fresh 3D-printing thread. I was thinking perhaps we could start a Rennlist group on thingiverse* and gather up our Porsche prints?
Only modeled the fan **** right now but i plan to do more things..
Any one happen to be in possesion of CAD models for the 968 mirrors or door handles?
*Thingiverse is a site for sharing 3d-printingfiles (STL)
Edit: I made a group
http://www.thingiverse.com/groups/rennlist/things
Old 05-30-2016, 12:28 PM
  #126
voo-doo
voo-doo's Avatar
How about the inserts for the early door handles? Since they a NLA.
Old 05-30-2016, 01:04 PM
  #127
Tom M'Guinn
Tom M'Guinn's Avatar
Cool! I just joined the group and will upload a few files.
Old 06-01-2016, 05:07 PM
  #128
Kongsodoken
Kongsodoken's Avatar
No pictures but I printed the ignition wire holders and the headlight adjuster inserts. But are NLA
Old 06-01-2016, 06:19 PM
  #129
thirdgenbird
thirdgenbird's Avatar
Great work.
That was the first thing I thought about.
Old 06-04-2016, 08:14 PM
  #130
azbanks
Freedom Enthusiast
azbanks's Avatar
Originally Posted by 944TurboYYC
The material (polyurethane) is highly resistant to oil and chemicals (except solvents, gasoline), so engine oil is one of the things I'm not worried about.
If someone can take a temp reading of this area using an infrared gun or similar, I'd feel more confident.
What would be good material choices for parts that encounter high heat and gasoline?
Old 06-07-2016, 07:29 PM
  #131
azbanks
Freedom Enthusiast
azbanks's Avatar
Does anyone have a file for a plug to replace the headlight washer nozzle?
Old 06-12-2016, 04:24 PM
  #132
Dave951
Dave951's Avatar
Would anyone be willing to 3D print the plastic locking chuck on the factory spare tire air compressor? Mine is barely held together with epoxy and I'd imagine this is probably a common failure part on these otherwise great compressors.
Old 06-12-2016, 05:08 PM
  #133
KVDR
KVDR's Avatar
I'll take a look at mine and see if it's do-able. If there's a need, I can print 'em.
Old 06-13-2016, 12:42 AM
  #134
CyCloNe!
CyCloNe!'s Avatar
What there's new colors! Dang may have to order more
Old 06-16-2016, 09:12 PM
  #135
KVDR
KVDR's Avatar
Default Shifter Vibration Dampers
You guys are going to like this one!
Ever since I installed the Only944 shifter, I've been annoyed by how loose the **** felt with re-using the stock shifter vibration dampers.
I'm not sure if this is the case for everyone, but the Only944 shifter I bought is slightly thinner (3/16" / ~4.75mm) than the stock one (~1/4" / 6.1mm), so the dampers have quite a bit of play.
OEM vibration dampers on Only944 shifter.
Factory shifter left, Only944 shifter right
I've actually had to change my hand position when shifting gears so the **** wouldn't twist.
Voila! Narrower vibration dampers to fit the Only944 shifter nice and tight. They're also quite a bit firmer than the factory rubber ones. These are a perfect fit on both the shifter and inside the ****.
I didn't want to leave anyone out, so I also sized a pair for the OEM shifter.
I ignored the ribs on the OEM versions - it would be difficult to print these and they don't seem necessary.
For those without printers or access to one, I've made a couple eBay listings:
Only944 shifter version
OEM shifter version
Desert Duck (03-29-2020)
Quick Reply: 3D Printing 924 & 944 Parts - Development and Discussion
