Karl's 944 Thread
Old 09-12-2015, 03:04 AM
  #136
Karl_W944
Karl_W944's Avatar
Gonna have another go at the trans fluid this week, but for now, I spent the majority of my free time detailing the car even more. Had another round with Meguiar's Ultimate Polish, applied by hand, and finished off with Klasse Sealant Glaze. Needs some more touch-up here and there, but that red really pops now!
I can't wait to see the results in the morning under the sun!!
Old 09-13-2015, 03:21 PM
  #137
EliteThink
EliteThink's Avatar
how often does the fluid need to be changed?
Old 09-13-2015, 08:42 PM
  #138
SloMo228
SloMo228's Avatar
Depends on your usage. If you're running the car hard on the track, you should probably change it at least once a year, if not more. For normal use, once every 3 years or so is probably adequate. IIRC the spec in the owner's manual is 30,000 miles? Could be wrong on that, though, that's just going off the top of my head.
Old 09-16-2015, 12:02 PM
  #139
Karl_W944
Karl_W944's Avatar
I bought a gopro yesterday and went for a nice drive in the evening!
Old 09-18-2015, 07:29 PM
  #140
Karl_W944
Karl_W944's Avatar
Default Trans Fluid Round 2
I got new plugs for the trans. And now that I'll be using an even longer torque wrench, hopefully I should be able to remove it this time!(I hope)
Old 09-19-2015, 11:56 AM
  #141
Karl_W944
Karl_W944's Avatar
Default Damn bolts still -_-
I must be doing something wrong. Is it counterclockwise or clockwise to loosen these damn bolts??
Old 09-26-2015, 03:07 AM
  #142
Karl_W944
Karl_W944's Avatar
Default Plugs Loosened!! ^_^
Had my favorite local Porsche shop loosen the plugs for me. It was much easier with more than 4ft of space to stand underneath and a much hotter burning torch to get the fill plug out.
I'll be changing the fluid finally, tomorrow morning after Cars & Coffee.
Old 09-26-2015, 12:24 PM
  #143
Tiger03447
Tiger03447's Avatar
Nice drive with the 944, Karl! Now I know what to expect when I finally get mine going! I didn't know that an acetylene torch was necessary to get the fill plug out. I tried with my propane torch and was unsuccessful. Looks as though mine will have to be drilled out before removal.
Old 09-26-2015, 03:18 PM
  #144
Karl_W944
Karl_W944's Avatar
Default Karl's 944 Thread
Trans fluids been finally changed!! I haven't had much time to break it in, but I'm not hearing any thuds into gear anymore.
The only way to know for sure is to see if it grinds shifting quicker into 2nd. Should be interesting.
Old 09-29-2015, 11:47 AM
  #145
Karl_W944
Karl_W944's Avatar
After driving around with the new fluid the past few days, it really made the difference! No more grinding into 2nd whatsoever!! I have much more confidence in my shifts now and can enjoy driving spiritedly more than I have in the past!
If anyone's looking for a video on how to change the fluid, I made a POV video on how to do that!!
Old 09-29-2015, 06:23 PM
  #146
CyCloNe!
CyCloNe!'s Avatar
Awesome congrats! Love it when its a simple fix
Old 10-22-2015, 04:15 PM
  #147
Karl_W944
Karl_W944's Avatar
Default Overheating Problems(Again)
I've noticed this past weekend and now, the car is running much hotter than ever, in fact, it's touched the yellow box on the temp gauge many times, and even gone into it but never going all the way to the end.
There's still more than enough coolant in the car, I do have the later-style 6-blade fan, with only the driver side fan running because of the passenger side fan not running(I recall that being remedied with upgrading the fan relay?), and replaced the 25A fuse with a proper 16A fuse today. Sometimes it would take longer for the cooling fan to turn on than I'd like to, and it goes on and off intermittently, unless that's normal?
What else could have gone wrong? bad thermostat?
Old 10-23-2015, 11:48 PM
  #148
CyCloNe!
CyCloNe!'s Avatar
make sure you don't have air in the system, make sure temp gauge sensor is correct, if all is good then probably a thermostat.
My understanding with the fan is there are multiple speeds so if you car gets too hot both fans should kick on. Only one fan should be on during normal running and if using a/c I believe both cut on. Could be wrong here but I believe thats the operation.
Old 10-24-2015, 03:24 PM
  #149
Karl_W944
Karl_W944's Avatar
I'm ordering a fan switch on Monday. it's cheap and easy enough to give it a try and see what results I get from it.
Old 11-09-2015, 06:07 PM
  #150
Karl_W944
Karl_W944's Avatar
My POV how-to video on my "success" in changing the thermofan switch:
This one had many mishaps, but I'm still a noob at this haha.
Quick Reply: Karl's 944 Thread
