Summer build thread: Megasquirt and more...
#151
Thanks Odonnell n Dougs951S
After a year or so of playing around with trying to get my own hand built MS II to work in My '86 I finally got the car running and moving under power controlled by MS II
Got the Mistress going about 85 and not bucking or popping and backfiring actually pretty smooth at speed but the take off map still needs work a lil off idle dip. but the car is drivable..
Yeah Me...
But this wouldn't be possible without the insight and help that these 2 Men provided directly or indirectly from post or answering direct question Michael your ignition and AFR maps were a Godsend
used them to set and calibrate my VE maps... Still have a few bugs to work out... 1 tach doesn't work. need to purge air from cooling system too many temp fluctuations amazing what you notice after
looking at your data logs.... figure out away to truly make a cold air intake got rid of Airbox and AFM running a cone airfilter with autozone generic 3" intake tube necked down to fit the J boot with the
IAT plumbed into the tube I am see 160* airtemp sitting still the airfilter is resting on top of the Alt so when the Rad fan fires up I'm sucking hot air, but moving there no problem... think that might be part
of my off idle dip problem..
So here's my setup as it stands
MS II Diy Autotune kit Ver 3.0 untimed Injection, Single coil, extra MPX4250 MAP Sensor MAP for Alt correction I live at almost 5K Alt
HC 05 Bluetooth Module and FTDI USB to Serial Module are hard wired in for tuning.
Injectors: 4 Bosch 0280155868 flows 375 cc/min at a tested pressure of 3 bar, or 36 lbs/hr at 43.5 psi.
flows 342 cc/min at a tested pressure of 2.5bar, or 33 lbs/hr at 36.2594 psi.
Latency (dead time)@ 12volts=0.621 ms @ 14volts=0.391 ms. I have it set to 13volts=0.500 ms Battery Offset= .118
FUEL NOZZLE: 4-HOLE DISC - Ultimate Atomization High-impedance/high-resistance/14.0 Ohms
Crank Wheel http://www.goingsuperfast.com 944 Trigger Wheel
Crank Sensor BWD Part # CSS718 out of a ford
IAT Sensor BWD WT3051 98 99 00 01 Mustang 4.6
TPS Sensor 944 Turbo
CLT Sensor 944
944 DME Male connector 825213-1 35 POS TAB HOUSING http://www.te.com/usa-en/home.html . But I still had make a custom wire harness prob integrate it all into stock harness
Wide Band O2 Sensor Controller Spartan 2 OEM from 14Point7 http://www.14point7.com/products/spartan-2-oem
O2 Sensor Bosch LSU 4.9 Wideband O2 Sensor
Idle Control Valve Bosch 2 wire Idle Control Valve from a Volvo p/n GEGT7610-324
Thanks again Odonnell n Dougs951S
Yeah Me...
CLT Sensor 944
#153
Idle Valve Mod
Did the idle valve mod to MS II the valve is 2 wires one to switched 12v and one to IAC pin on MS II then set it up in tuner studio
I decided to disable it for right now while tuning.. Will do more with it when I get back to the cold of Utah where It I will need it more starts fine in Socal without it..
Basically I want the car to run on just the set screw on the throttle and the built in idle control screw for now . so far the car will run and not cut off when throttle closes suddenly
Did the maiden shakedown tuning run a 750 mile road trip from Utah to San Diego from 5,050 ft down to 390 ft had some struggles in the beginning but after doing some side of the highway troubleshooting at 3 am found one injector disconnected 'cause the 30+ yr old wires broke right where I spliced in the new injector plug (Porsche Harness must go) so I was chasing my tail to get the right AFR and VE tables but after sorting that out and deciding to add Apha-N to the ignition load table wow it was a different car, the car would accelerate going up hill without downshifting, for the most part after getting up to speed it was like driving an automatic going from 60 to 80 mph to pass someone or to climb all but the steepest grades was just a push of the throttle now if I could just get the cruise control to work when I want it... Will prob try to add Percent Baro correction to the secondary fuel load tuning on the way back right now I am tuning for it to run a lil rich, when I get the VE maps where I like it I will change the AFR tables to lean it out so if I loose the O2 sensor I won't burn the motor up I did that befor with my first Porsche I owned a '80 924 turbo lost the O2 sensor and I had raised the boost and it melted the Alu head and pistons the seats actually fell out of the head.....
Thinking of having it dyno tuned work out a couple ruff spots and do side by side of the Focus 9 tech DME and the megasquirt also playing around with injector dead time since I can't find a spec for my injectors at 13v. plus it is working at a lower fuel pressure so the injector opens faster, Already thinking ahead of adding and adjustable fuel pressure regulator and maybe a custom ram air airbox under the front header panel like the 924 turbo...
#154
msq file not available
Hi michael,
great thread / build!
the download url to the msq file is not available. Is it possible get a new link to download the file?
(goldberg.boris@gmail.com)
I’m in the process of microsquirting my 83 944. It will be great to have a good valid staring base for tuning..
thanks! Boris.
thanks! Boris.
That's probably the best solution, I've just never seen a complete 944S in person and have no idea. But yeah, that would be really clean assuming the cam gear had the provision for the pickup to read it.
Edit: I forgot! The wiring is basically done. Made a quick video of the final steps needed to remove the factory harness without losing functionality, and also the tach setup.
So a couple people asked about tuning maps...finally got things in order on that front. Not perfect - but very drivable and in my car, pulls a lot harder than the DME ever had it. This is not a dyno tune but is very streetable. I generally tweak it every time I drive, so this is more of a 'starting point' than a final word. Another important consideration is that my motor is probably different from yours if you download and run this tune...I have a slightly more aggressive cam than stock, and a 5 angle valve grind which will make my VEs a little higher at high RPMs. However, this will still work ok for a stock 8v 944 NA, just be prepared to tweak and refine. DO NOT load this map without intending to follow through and tweak it for your own application.
3D representation of the fuel map:
Link to the MSQ file - PM me if it ever goes down. https://dl.dropboxusercontent.com/u/...7_16.18.20.msq
The MSQ file also includes an ignition map - it is very conservative and when my car is dyno tuned, I'll share it. But that should get you started.
Make sure you go through all the engine setup setting and make sure it is configured right! There are a lot of areas where my build is different. For example - tooth #1 angle (missing tooth offset relative to TDC), the coil dwell and configuration, and the req_fuel variable. req_fuel is very important, unless you used the same injectors as me yours will be different. You need to have all this ironed out before you load anyone elses tune.
Another thing is the enrichment curve setup. Mine is tailored to a car with an early aux air valve and a lower temp thermostat than stock. Yep, even stuff like your thermostat comes into play because that affects how the car warms up. So long story short, you need to redo all the settings that transition the engine from cold to warm.
Alright, all warnings aside, this is totally worth it and hopefully this makes it more accessible for other 944 enthusiasts to migrate to a standalone setup if they desire to.
#155
Adding my current tune. I heard a little bit of pinging on a hot day the last time I wound it up, so you may want to take 1-2deg of timing out across the board. May have been the gas in my tank not being the octane it claimed... first I had heard it. My cam is also advanced 4deg with a key.
#156
Yeah Me...
CLT Sensor 944
Yeah Me...
CLT Sensor 944
thanks for sharing
#157
I'm using the stock coil driven by an ISL9V3040P3 Transistor ( https://www.onsemi.com/pdf/datasheet/isl9v3040p3-d.pdf )
I am using a stock S2 flywheel it bolts right up it a 60 -2 tooth setup it had a front mount 32 -1 gave a lot of issues still using a stock bosch
VR sensor .
My setup now is totally different I will post a separate update on that.
VR sensor .
#158
Yeah Me...
CLT Sensor 944
Yeah Me...
CLT Sensor 944
My current setups
1: Megasquirtpnp gen2 p8791 for 87-91 944s-s2
https://www.diyautotune.com/product/...sche-944-s-s2/
Modified to run stock coil with a ISL9V3040P3 Transistor ( https://www.onsemi.com/pdf/datasheet/isl9v3040p3-d.pdf )
S flywheel using NA clutch n pressure plate and bell housing
S engine harness
Injectors: Bosch 0280155868 brown tops 4-HOLE DISC - Ultimate Atomization High-impedance/high-resistance/14.0 Ohms
CLT Sensor 944
IAT Sensor GM
2: MS3Pro Module with a custom design interface board for 944s-s2 Harness running a 88 Turbo motor
S engine harness with modifications
Injectors: Bosch 0280150558 = Ford M-9593-F302 rated at 42 lb green tops 4-HOLE DISC for Better Atomization High-impedance/high-resistance/14.0 Ohms
CLT Sensor 944
IAT Sensor GM mounted 4in from throttle body
O2 Sensor Bosch LSU 4.9 Wideband O2 Sensor mounted in down pipe aft of turbo
the wire from the vent valve used to drive the stock cyclic valve
The interface board is a work in progress
MS3Pro Module can run sequential injector coil on plug but running batch fire right now until I figure out how to get
a cam sensor mounted.
Megasquirtpnp gen2 p8791 for 87-91 944s-s2 can also run the turbo motor
walfreyydo (01-25-2023)
#159
Update of my current setup after 6yrs
My current setups
S engine harness
CLT Sensor 944
IAT Sensor GM
CLT Sensor 944
https://www.youtube.com/shorts/t7YRPi6pQB0
https://www.youtube.com/watch?v=fO9pAFRxP-c
My current setups
S engine harness
CLT Sensor 944
IAT Sensor GM
CLT Sensor 944
Can you point me or tell me the details about wiring up the transistor? The Megasquirtpnp gen2 box you got works only on the 1987+ cars because? (the flywheel + sensor quality and the TPS on those cars?).
#160
I am planning on doing the DIYAutotune PnP Megasquirt setup this spring on my S2 as well. Great thread and appreciate the data and insights. This will help my own implementation tremendously!
#161
thanks for the information. I have a 2.7 motor installed in a 83 track car. I am not sure now that I have installed the motor what flywheel I installed. I got boxes of parts and an engine on a pallet. is there an easy way to tell what flywheel I might have?
Porsche 944 8791 MegaSquirt Gen2 Plug and Play Standalone Engine Management System
*Fits Porsche models:
Porsche 944 8791 MegaSquirt Gen2 Plug and Play is incredibly easy to install and use. Mounts in the factory ECU location.
- 1987-1988 944S
- 1989-1991 944S2
The plug and play kit continues to use the stock engine harness wiring and DME plug and you just swap the DME for the MS ECU which plugs directly into the stock plug/wiring. On the 8V cars this is all different and its likely going to be easier to do the universal MS route for an 8V car. However going this route would require you to re-wire everything on the engine harness side - ie: reconnect everything from the MS system to the engine sensors. The standard/universal MS setup will have like 8ft of all the wires needed for each sensor input needed for MS that you would have to run and crimp/solder to each sensor on the engine side or re-use existing wiring and re-pin into the MS harness. There is a good guide on this on these forums called A Practical Guide to Megasquirting your 944 which may better guide you on setting up MS on the 8V cars.
There are numerous differences between the 16V cars and 8V cars. The whole engine side wiring harness, DME plug and pinouts are different. They have a different flywheel with a different number of crank sensor pickup points (?). The 16V cars only have one crank sensor (reference sensor) vs the 8V cars which have a speed and a reference sensor (2 sensors). Ignition system is also different with the 16V cars having a ignition control module where the 8V cars dont.
#162
The DIYAutotune setup is only usable on 16V cars - although you can still go the universal MS route (not plug and play):
#163
you can get the trans from diyauto tune I will post a pic of how i installed it
walfreyydo (01-27-2023)
#164
#165
Probably also need to convert from a speed + reference sensor (8V cars) to just a reference sensor (16V cars)-which would be part of the wiring swap. I think the sensor bracket is the same between both 8V and 16V. Also likely have to include the ignition control module which is present on the 16V cars as well, also likely part of that wiring swap.
