My timing belt / gaskets / exhaust replacement has begun
Old 04-21-2015, 07:17 PM
  #46
joeystanker
joeystanker's Avatar
UPDATE
Just dropped the cylinder head off at Autosport Seattle
They are gonna spruce her up.
Really nice fellas and WOW, what an amazing display of gorgeous old cars they are working on.
SLURP!
Old 04-22-2015, 10:56 AM
  #47
Tiger03447
Tiger03447's Avatar
Default cylinder head
good move, Joey...hope that it is OK, and not too much work has to be done to it.
Old 04-22-2015, 11:11 AM
  #48
joeystanker
Thanks for the recommendation Tiger.
The guys there gave me a good impression.
Even if there is a lot of work it's okay.
I'll be glad it will be right.
Old 05-02-2015, 10:36 PM
  #49
joeystanker
UPDATE:
While the head is at the machine shop waiting for sleeves and the final touches... I have been busy
- CV Joints re-installed and good to go
- Fuel filter replaced. The injectors arrived rebuilt and beautiful. Their performance report looked good and recommended I replace my fuel filter. Done
- While removing check valve from the brake booster it fell apart and a piece fell in to the booster. The little diver was extracted with a $29 endoscope
- Throttle body removed, cleaned, and ready to be re-installed with a new gasket
- Front seals replaced (crankshaft and balance shaft seals). Rear timing belt cover and sprockets re-installed, as well as a tensioner and a roller
When the head and the camshaft is re-installed and can put some belts and the other sprockets/roller/tensioner on.
Until then I think I might drill out those spot welds on the nose and properly install a beautiful new badge with gasket.
Also, I will tuck my upgraded headlight wiring in the nose and switch the headlight power feed from the battery to the alternator.
It finally feels like I'm putting this car back together!
Old 05-05-2015, 11:59 PM
  #50
Tiger03447
Tiger03447's Avatar
Nice pics, Joey! glad you recovered the piece out of the booster...looks like you'll be having a "going jesse" there pretty soon with all the new parts and all...Hope I can post some pics too when the time arrives..
Old 05-06-2015, 05:34 PM
  #51
joeystanker
Tiger, thanks for expanding my ever lacking vocabulary today:
Going Jesse
Gorgeous, I love it.
Old 05-07-2015, 12:10 PM
  #52
joeystanker
I was thinking I might want to clean all of that crap from my intake manifold.
This looks like a winner:
Thanks to YouTube user: BMAC VAGS
I'm so stoked I can clean the insides.
Old 05-07-2015, 12:25 PM
  #53
joeystanker
UPDATE
- Drilled out the spot welds on the nose. Now I can re-route my headlight wire harness and replace that glued on badge
Old 05-07-2015, 12:44 PM
  #54
odonnell
odonnell's Avatar
Joey, was your old waterpump the original part? I see "21983A" stamped on it.
Old 05-07-2015, 02:42 PM
  #55
joeystanker
Nope, it was the upgraded water pump with the belt guide on it.
I bought the replacement new on EBay:
Porsche Engine Cooling Water Pump Premium 94402122
http://www.ebay.com/itm/131414861974
These are the mounting posts for the guide
Old 05-15-2015, 04:49 PM
  #56
joeystanker
UPDATE
- Booster check valve replaced
- Intake manifold and camshaft housing cleaned and turned over to powder coating
- Camshaft sprocket housing and heater coolant rail being polished to a shine
- Badge replaced, now with no glue and a gasket
- Nose spot welds now replaced with sheet metal screws and trimmed washers
- Headlight upgrade wiring now powered by alternator instead of the battery
- Positive battery cabling cleaned up a bit
- Added shielding and cleaned up oil pressure sender wiring. A post on the sender snapped. I didn't think I was tightening that much. A new sender is on the way
Old 05-16-2015, 05:07 PM
  #57
joeystanker
UPDATE
- Camshaft sprocket cover cleaning and polishing finished
- AC controls mounted in their new home
Old 05-17-2015, 10:59 AM
  #58
Tiger03447
Tiger03447's Avatar
Looking great, Joey! Keep up the great work! Hopefully mine will be going back together this week (just the engine)...so reconstruction progress is finally being made! WOO HOO!
Old 05-29-2015, 11:02 PM
  #59
joeystanker
UPDATE
- Oil Pressure Sender replaced and wiring jacketed
- Shifter upgrade to thrust bearings begun. Waiting for McMasters thrust bearings to arrive
- Cylinder Head fetched from the machine shop: http://autosportseattle.com/ . It looks beautiful.
- Camshaft Housing and Intake manifold fetched from powder coating: http://www.seattlepowdercoat.com/. They look beautiful.
- Cylinder Head installed.
I am waiting for some pretty new hardware to arrive before I put the rest together.
Old 06-03-2015, 10:28 AM
  #60
JoeBoxer
Cruisin'
JoeBoxer's Avatar
Hi there! Hey , do you always use easy off oven cleaner as the best parts degreaser? Gonna give it a try..
Quick Reply: My timing belt / gaskets / exhaust replacement has begun
