When is it time to change out the rod bearings & oil pan gasket?
I bet if you take the radiator out, slide the engine forward of the torque tube, disconnect the wiring harness, then lift the engine up 10 inches so you can clear the oil pickup tube, you could do the pan gasket. But, if you're going to lift the engine up 10", you might as well take it all the way out.
Or you can drop the crossmember.
I use Blackstone Labs.
In my experience with pulling the engines out of these cars the torque tube would have to come back and you would need to lift straight up to avoid removing the X-member. If you try to slide the engine forward off of the torque tube you will find that the oil pan bumps into the crossmember, requiring you to remove it for the engine to come far enough forward to disengage the torque tube/driveshaft from the clutch/bellhousing.
Correct me if I'm wrong, but I remember having this very issue when I was doing my swap...had to drop the crossmember out of the car to pull the engine out the top.
Ethan
I just swapped my motor on my S2 cab and I went out the top. In the end I had to drop the cross-member about 6 inches in order to clear the oil pan and disconnect the TT. Did not have to remove the radiator just the fans.
Mark
Mark
Yep, I've heard it's a fairly simple job myself though never actually done it.
It's just "bolt off and bolt on" right? Using proper torque settings and things like that of course.
This one seems more followable:
http://www.paragon-products.com/kb_results.asp?ID=63
However, when looking at these pieces, which are not too expensive compared to some of the Lindsey line, if I were to go with these, would swapping the original parts with the Lindey parts save me time upfront or only on subsequent jobs? I'm thinking the latter
http://www.lindseyracing.com/LR/Part...OSSMEMBER.html
http://www.lindseyracing.com/LR/Parts/944XOVRKKK.html
When I rebuilt my engine 5 years ago we pulled it out the top. It was a pain and took 4-5 hours. Putting it in from the bottom..... 2 hours. Don't waste time dropping that the entire assembly out the bottom attached to the subframe and then disassembling is much easier. That's the way that factory built them.
I think he meant -
Don't waste time, dropping that the entire assembly out the bottom (while) attached to the subframe, and then disassembling, is much easier.
Don't waste time. Drop the entire assembly (leaving it attached to the subframe) out from the bottom. Then disassemble the dropped assembly. That is much easier.
Correct?
That's how I do it. I've actually made a dolly that has wheels and bolts to the sub frame. Then I can lift the car up and roll the engine away. Take the bell housing off, put on an engine stand bracket, put it on the engine stand, then pull off the dolly and sub frame.
Was looking at the past invoices and found:
Date of Service: 10/1/2007
Mileage: 142,515
Parts: "Rod Bearing Set" $111.47
Labor: "(Combination) CONNECTING ROD BEARINGS - Replace - All" : 1.4 Hrs $127.75
Date of Service: 12/20/2010
Mileage: 152,689
Parts: "Rod Bearing Set" $162.87
Labor: "(Combination) CONNECTING ROD BEARINGS - Replace - One" : 2.0 Hrs $202.50
Current mileage is ~174,000
Q1: "Rod Bearing Set" = "Rod Bearing Kit"?
Q2: "(Combination) CONNECTING ROD BEARINGS" = "Rod Bearings"?
Q3: My research shows this is a 16-20 hour job but the labor here shows 1.4 and 2.0 hours, most likely due to the major expense being the oil pan gasket replacement?
Q4: On the later invoice (2010), this seems like only one bearing was replaced. Why not replace them all while you're "in there"?
Q5: If all the rod bearings were replaced at 142k miles and I'm now at 174k miles, I should wait at least another 50k-60k miles before doing this?
Mileage: 142,515
Mileage: 152,689
Q1 - yes
Q2 - yes
Q3 - you tell us - are there more labor items for oil pan gasket and alignment?
Q4 - you'd have to ask the shop that question...
Q5 - this is a matter of personal preference... according to the invoices, at least 1 rod bearing needed to be replaced after 10k miles. It's been 32k miles since they were last looked at and/or replaced. You might be able to go another 50k-60k miles, but the answer to that is your own risk/reward tolerance.
Q2 - yes
Just a car guy
I don't recall any issues - though it was probably ten years ago, now. Not to mention... I don't recall what I had for dinner last night.
