When is it time to change out the rod bearings & oil pan gasket?
I bought a rod bearing kit from 944online (oil pan gasket, nuts, rod bearings).
How do I know when the old ones are at their end and time for a replacement?
Also it didn't come with an instructional guide like the only944 parts do and I couldn't find anything with pictures online. Anyone know of a good tutorial?
1986 951
1986 951
Two schools of thought on this.
Do you track your car or is it street miles only? What mileage is on the motor?
I dont think rod bearing replacement is a bad idea if your pushing 125k+ miles, but for a street driven only car i probably wouldnt bother doing it unless the oil pan gasket was leaking.
If you track the car, i would consider replacing them as part of preventative maintenance depending on mileage.
The only indicators that the bearings are bad are either rod knock (which means its too late), low oil pressure (you probably wont see this until its knocking) or doing oil analysis and developing a trend over time.
https://rennlist.com/forums/944-turb...pictorial.html
Well,it happened to my friend today.Less than 10k km on a total rebuild.Car was running mint,then bam! without warning…no oil pressure and a horrible clackityclack sound.He's not a happy camper with the rebuild done not long ago….I guess when it's your time,it's your time…no warning
If the car has been tracked, I have a number of knowledgeable folks who recommend changing the rod bearings every 40 track hours. In particular, the #3 bearing oiler is awkwardly designed to throw oil in the proper direction. As a result, that's the least well-oiled of the four. For a street car, I wouldn't bother until after 100k.
Or you can drop the crossmember.
I use Blackstone Labs.
I do them every 30 hours on our race cars. Street car, 140k is usually the mark I like seeing them done at with experience to pulling them out at various mileage intervals. The rod bearings that have been spun on street cars that I have seen have all been a quart low (or more!) on oil when I checked them after coming into the shop.
