Please help me figure out what's wrong with my 944S (Soundbite)
Hi all,
I am running out of ideas on what could be the source of a rough running, missing, 944S. I recorded the sound from the muffler with my iPhone so you can hear how uneven it is including two pops.
https://soundcloud.com/christopher-c...e/944s/s-6YNR1
I have done:
Plugs, Coil, HALL sender, and the DME temp sensor. The cap/rotor are next but I haven't seen any arcing. The also looked in very good shape but before I throw more money at it just wanted to see if others might have some insight.
Fuel pressure is good and it passes the leak down test. Should I be chasing vacuum or really am what I am experiencing is bad injectors?
Thanks,
Chris
I have done:
Thanks,
Chris
I suppose it could be a dirty injector or maybe just a dirty air filter. Have you checked these? Do you know what cylinder it's coming from? Sounds like a misfire to me.
I have one clue I just remembered. When I first got the car #4 plug was pretty wet maybe even oily? almost like it was never firing. I figured bad plugs. If I pull them and #4 is different from 1-3 then I'll chase that one specifically.
I'll also go on the hunt for a vacuum leak. Clarke's Garage says to pressurize the intake manifold and listen for leaks. I tried this once but didn't really hear much. I removed the vacuum line from the Fuel damper while running and it had good vacuum so I am thinking that's not it.
Chris
EDIT:
I checking this morning with my old timing light and each wire is working and the cap is solid (no cracks). It even runs a little better cold. The idle does hunt a little (just barely) . I pulled the small vacuum line off the Brake Booster and there was no change to the engine. When I get a chance to pull the plugs maybe I am chasing a vac leak.
Sounds similar to this thread. https://rennlist.com/forums/924-931-...ntil-warm.html
Check that the screws securing the rotor are tight.
