Idle speed starts low and increases until warm
My early car starts at a low idle when cold then it continues going up until it is warm. This has forced me to set the idle screw so that I idle at about 700rpm immediately after start, up to about 1900rpm when warm! Does anyone know how idle is regulated on the early cars so that I can get it idling in a reasonable range?
What about the DME temp sensor? I know that regulates the EFI for cold starts. Try unplugging it and seeing if it acts any differently (easy variable to eliminate).
I was thinking it might be the temp sensor, I hadn't thought of just pulling the plug to see what happens.
Well, the DME temp sensor ohms out okay when cold, so I doubt that is the issue. I will test it warm tomorrow just to make sure, but I think I'm still going to be searching. What else does the DME use to control the idle on the early cars?
