no spark
My car started fine Sunday afternoon but Monday it would not crank up and some check I find that I have no spark from the coil any idea on the were the problem is. Just FYI I have tach bounce.
Here what I know already the DME relay is new, I have fuel at the rail and no spark at the coil. so my guess is the DME or the coil I'm going to see if I have power to the DME and good signal from the sensors using the LED trick this afternoon.
I see they are calling for a high temp of -2 degF in Minot today. At what temperature does electricity just give up and refuse to flow?
Don't assume your DME relay is good just because it is new. It is the easiest thing to check, all you need is a paperclip to wrap around the terminals.
Doh, that's right. As in cryogenic superconductors! All the same, I'll pass on Minot in the winter.
HTML Code:
Electrons actually flow better at lower temperatures
