Which clutch for supercharged S2??
My stock Sachs clutch is nearing the end of its life. The clutch has been holding up OK so far considering its working with my supercharged S2 with (currently) about 270 ft-lb of torque. It is interesting the S2 uses the same clutch as the NA, so the NA must be really over-engineered, and with my engine you would think it is near its limit.
I will also be replacing the stock flywheel with an aluminium one.
Car use is mainly track and occasional street.
The options seem to be:
Standard Sachs replacement - full face organic compound clutch
http://www.lindseyracing.com/LR/Pors...SAC-944S2.html
Centreforce
"Centerforce Dual Friction disc has a full facing on the pressure plate side for drivability and longevity, while a carbon composite puc-style (segmented) facing is used on the flywheel side for a positive engagement and increased holding-capacity."
https://www.centerforce.com/products...91-porsche-944
![Name: CF Clutch.jpg
Size: 97.3 KB](https://rennlist.com/forums/attachments/924-931-944-951-968-forum/717911d1365209836-which-clutch-for-supercharged-s2-cf-clutch.jpg)
Spec Stage 1 or 2:
Stage 1
Features an integrally molded carbon kevlar-based, high performance organic lining that offers smooth engagement and excellent life. This lining has an integrally bonded steel backing for strength under high clamp loads and temperatures. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Best for street and many track/off-road applications.
Stage 2
Features segmented or full faced pure Kevlar disc with steel backing. This lining features excellent drivability like the stage 1, but offers slightly longer life and higher torque capacity. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Best for street, drag, pulling and autocross.
![Name: Spec Clutch.jpg
Size: 18.3 KB](https://rennlist.com/forums/attachments/924-931-944-951-968-forum/717902d1365209035-which-clutch-for-supercharged-s2-spec-clutch.jpg)
From the max torque info, it seems that I should be going for Stage 2 over Stage 1. (But the standard Sachs has been working OK so far - so these seem a little pessimistic.)
KEP
No KEP clutches for the S2.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I'm after opinions on the drivability of the Centreforce and the Spec Stage 1 and 2.
From searches I have done here, the opinion on the Spec Stage 2 seems to be divided between really good and terrible. Reviews also seem to indicate they are chattery to start but bed in after some k's.
I haven't heard much about the CF clutches, but they look good.
So which to get???
Centreforce
Spec Stage 1 or 2:
Stage 1
Stage 2
KEP
So which to get???
The stock clutch seems to be OK, but is near its wear limit. Also, I forgot to mention that I will be increasing the engine power in the future, so I'm dubious a new Sachs would be sufficient - but who knows?
Also to add to the list there is also the SPEC Stage 3+
The flagship stage for a high powered street or race car that requires a manageable and friendly engagement, the stage 3+ features a carbon semi-metallic full faced material that offers unparalleled life, friction co-efficient and drivability characteristics in one single package. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Great for street, drag, drift, autocross, road racing, pulling, rallye and drift.
Is the Stage 3+ more or less street friendly than the Stage 2??
I've used the center force before. It worked well on my sc car. In the end that car made around 300 hp, and I abused the crap out of it at the strip. Felt very stock.
With that said, if I did it over now, I would have a (non rubber center) disk resurfaced with feramic. Check with dnovak on here or Southbend.
Going with the southbend would probably put my car off the road for too long given the turnaround time to Australia. Was the CF clutch grabby or did it chatter on the street?
Professional Hoon
Pauly
I thought your review implied there was not much transition between on and off for the spec 3+ ?
I also did some more web searching on Spec Stage 2 and 2+ clutches and found a LOT of negative feedback from squealing to grabbing, insufficient clamping force and early failure. Yikes.
So I'm now leaning towards the Centerforce clutch kit, or perhaps the CF pressure plate and Sachs friction disc.
The S2 really got the dud clutch compared to the turbo and 968 which both have larger discs.
Clutch is quite light. Will see how it goes on the track.
Cheers
Eric
